tc-p50S2 10 blink SC troubleshooting
  • tw2005
    • Oct 2011
    • 6458
    Re: tc-p50S2 10 blink SC troubleshooting
    post 7 & 14 is all the info and suggestions I can give you.
    UTSOURCE i got the bulk from there, there are subs for some of those common parts like the Toshiba logic chips ( eg TI) , voltage regs, signal transistors.
    I highlighted parts you could strip from a cheap SS board.
    Ebay and local suppliers. RS components here have free post for online purchases for Australia, maybe you have a similar supplier with same deal?
    UTSOURCE has a minimum unit cost of $1 so some of those bits are like 20-50c parts.
    They also tend to make the prices up sometimes, not unusual to get quoted more than their Ebay listing but I have also been quoted less too.
    You will be waiting a while with the $4 post from china.
    That's just the way it is.
    • glen65
      • Dec 2008
      • 30
      I've looked at UTSOURCE a few times but am concerned about quality.
      You seem to have experience with them, have you ever had any trouble
      in that department? Also (generally) how long does it take them to ship
      an order? Thanks.
      • tw2005
        • Oct 2011
        • 6458
        an order? Thanks.
        I've had no quality issues although sometimes the leads look a little suspect like it could be fake but touch wood every part I've received has worked and tested similar to what they should be.
        Some arrive with pre bent leads which are sometimes in the wrong direction needing careful rebending to install them . Mainly the panasonic IGBTs. Some have a R stamped and they are always bent in the opposite direction to the non R. originally i thought it was an electrical difference but now I think it simply means the leads are pre-bent in the reverse direction as part of the factory process.
        I have no evidience to back the theory but no issues.
        delivery is slow unless you shell out for DHL etc which adds a good chunk of $$ but if the order was large enough may work cheaper but a good 3 weeks from china to Aust, maybe 4. No idea how transit is to the US, would not surprise me if it was quicker.
        They can take a while to compile the order but always well packed and static protected.
        i'm confident if you did get fakes they'd sort it out, I expect their intention is to supply good parts but I'm sure they get caught themselves.
        hope this helps.
        • glen65
          • Dec 2008
          • 30
          hope this helps.
          Thanks for the reply,
          I asked because I am currently working with a TNPA4844AD SC board
          with the following shorted components. 2PG011, RJP4585, RJP6065.
          These are obsolete numbers, and I cant seem to find anything to sub these IGBTs.
          The sticking point is the current spec. The 2PG011 for example, has a continuous current rating
          of 40 amps, (not too much problem there), BUT at the same time it has a
          pulse current rating into the 200 amp range. The highest I could find was
          about 160. If I cant bring myself to buy the HK semis, I'll just have to bite
          the bullet and pay the higher cost from Panasonic.
          • tw2005
            • Oct 2011
            • 6458
            UTSOURCE ,would have them and possibly Ebay.
            DG502LW should sub ok for the 2PG011, AFAIK that one superceeded it.
            RJP6065, i suspect RJP63F3 would do there
            At a couple of bucks each from UT, I'd take a chance but I do not recommend purely replacing the IGBTs that are shorted and expecting it to then work.
            odds are they will simply blow again.
            • glen65
              • Dec 2008
              • 30
              I wouldn't either,
              That's why I checked all other components such as transistors, diodes resistors, ect.
              Also checked the FET output pins of the M81707FP ICs for shorts. The SD and SU boards
              can be had pretty cheap, and might change them for good measure.
              • tw2005
                • Oct 2011
                • 6458
                Ok, well hope it works out. By all i assume all the SMD stuff as well, the voltage regulators and possibly failed inverter ICs, did you measure the resistance for the P5V and P15V lines in.
                • glen65
                  • Dec 2008
                  • 30
                  Yes
                  None of them are shorted, but not really a guarantee they are good.
                  I am assuming you are talking in respect to the circuit ground. If so
                  the yes I did. The resistance measured up into the kilo-ohms, on both
                  the 5 and 15 volt lines.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Yes
                    k ohms sounds like it could be ok, fet drivers usually go open on the output and or short or low ohms on the Vcc which i believe is the 15V in from the few I've played with but not your model
                    • allenrw
                      • Jul 2013
                      • 19
                      Here is the latest update, I started pricing parts and because they came from different sources including used Panasonic boards the price rose quite quickly and there was no certainty that I had found all the bad components.
                      I sat back and watched Ebay.
                      Don't you know it a week ago someone posted a SC, SU, SD board set as a new pull for $117 US delivered.
                      It works fine so far but I think there may be a clue as to why these boards go bad, some of the heat sinks get a bit warm so I am considering a couple of low noise fans mounted externally.
                      Thanks for the help TW2005, you made this a lot easier but it was still very time consuming, a great learning process.
                      My advice for a repair like this is to take the time to check the TV carefully at the component level looking for shorted components and missing voltages to determine which boards are bad (the blink codes were a bit misleading), then if it is a couple bad components that can be had for reasonable money fix it up, but if it turns out that there are many components then it is probably better to get a warranted used board.
                      The trick here I think is to take the time to verify that you find all the problems so you don't end up buying parts or boards and then have to buy more boards or damage your new boards because you missed something.
                      Once I discovered that there was a short in the SC board I disconnected it and checked the voltages on the P and A boards pretty carefully especially those related to the SC board.
                      It has been an adventure!
                      • carpetweb
                        • Nov 2012
                        • 1
                        • usa
                        #31
                        I had an sc board blow on my tcp50g25 13 months ago and replaced it with a new board...now 13 months later it blew again....I'm thinking its not worth the headache to find another board and repair it again. Will NEVER EVER buy panasonic again.
                        • janos666
                          Pioneer LX5090 - 2x Red blink after auto-shutdown
                          by janos666
                          I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
                          03-26-2023, 11:20 AM
                        • EazyBone
                          Un50cu7000 2 blink oddity *partially solved
                          by EazyBone
                          I write this to maybe help another with this TV.
                          So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                          The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                          03-18-2024, 10:24 PM
                        • kacangpolo
                          Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                          by kacangpolo
                          I have problem with my laptop, with code board X415EA 2.0,
                          laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                          I did :
                          1. Flash Bios
                          2. RTC_RST 3.3V
                          3. LID_SW 3.3V
                          4. WLAN_WAKE# 3.3V
                          08-26-2025, 04:42 AM
                        • Vebririon
                          panasonic TX-P50V10E 6 blink led problem
                          by Vebririon
                          Hi everyone,
                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                          05-17-2025, 10:16 AM
                        • cruiser_
                          A1466 820-00165 intermittent shutdown
                          by cruiser_
                          hi there,
                          Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                          Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                          Gives shutdown cause -128.
                          Seem to work fine in SMC bypass.
                          Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                          Observations:
                          - SMC_RESET_L - when pulled down - plug goes orange/green and...
                          10-11-2022, 12:06 PM
