Panasonic Plasma TC-P50S30 7 blinks fixed by replacing with differnet model SU/SD Boa
  • Sevenqi
    • Jul 2011
    • 292
    Panasonic Plasma TC-P50S30 7 blinks, open cover and took an eye inspection on the SC, SU/SD boards, no obvious damaged components were found.
    Checked SC board had voltage while turn on, but disappeared as the tv shut itself off.
    So what I did was:
    1. Isolated the SC board from the two buffers (SU/SD) by disconnecting.
    2. Shorted the SC50 (I used an old IDE hard drive jumper).
    3. Plug power cord and Turned on the TV, it powered up constantly, no blinks any more, TV response to the remote control.
    4. Unplug the power cord from the wall, wait for 5 minutes.
    5. Connected the SC board with the SU/SD board again, TV still turned off and gave 7 blinks.
    From this point, I suspected the buffer boards failed, this is a common issue for this model, most likely is the upper board problem, I think the culprit
    was that there are no heat sinks for the ICs on the boards. I checked the price on ebay, the upper buffer board was quite expensive.
    The two buffer board part numbers are TNPA5336AB/TNPA5337AB. I happed have a pair of TNPA5336AG/TNPA5337AG from Panasonic TC-P50GT30, which is a 3D plasma TV.
    Since the part numbers are the same only the suffix are different, I thought they should work.
    So I replaced the TNPA5336AB/TNPA5337AB with TNPA5336AG/TNPA5337AG, turn on, TV lite up ! Everything works !
    Please note I replaced as a pair. TNPA5336AG/TNPA5337AG boards have heat sinks on top of ICs, so I'm sure the these two boards are more reliable than the old pair.
    (The fourth photo was the original boards).
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TC-P50S30 7 blinks fixed by replacing with differnet model SU/SD
    Yes, if you do enough digging , it's fairly common to find a heatsinked/non-heatsinked buffer boards that are electrically the same.
    I know with the 2010 series , for example a V20 and a VT20 (3D) buffer set are not the same on the SD but the SU are the same.
    You can certainly increase your luck doing the research and sometimes works out cheaper.
    • Haptic8739
      • Jun 2014
      • 1
      • united states
      Hey there, i have same model tv, same issue, disconnected buffer boards, and tv turned on, and stayed on, when your buffer boards were disconnected, did you get like crazy psychadellic blotches floating all over the screen? Just curious, didnt know if that was indicative of something else wrong. Bad panel too perhaps, bought tv broke for $10, dont know its history.
      • tw2005
        • Oct 2011
        • 6458
        Normally you don't see much on the panel when doing this but if it no longer shows 7 blinks then i would say buffers are faulty and would not expect any other issues normally.
        • Prop1
          • Jun 2014
          • 93
          A low resistance failure of the SC board will cause weird pictures. Found that out on mine due to not reconnecting a bleed power resistor, which effective created the same effect. Also discovered that while using different buffer boards may work; it doesn't work the same for the SC. It has to be the right one.
          • electronicsurplus
            • Jun 2012
            • 210
            I wonder what the difference is between the various suffix on the SC, SU and SD
            (ie AJ, BK, BA, etc) As I have tried interchanging some with success and, some without. Is there some IC that would cause them to not work? Since, the Repair kit that ShopJimmy sells simply states TNPA5335 repair kit and does not reference a suffix at all, even though on the website does. There are no notes, etc. on the box or contents
            Any ideas?
            This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
            Help keep these from the landfills
            • tw2005
              • Oct 2011
              • 6458
              Any ideas?
              various suffixes can mean almost any variation. This could be components, circuitry or simply different connectors and heatsinks.
              If you want to know , you'll have to do your own research and comparisons whether it be visual comparison, comparing schematics , part lists etc
              • electronicsurplus
                • Jun 2012
                • 210
                They are visually the same, Same Connectors, same components and, the same circuitry
                I am wondering if they contain some type of eeprom or something that causes them to be different? The only thing I can see different is the part #
                • tw2005
                  • Oct 2011
                  • 6458
                  no eeprom, but i can tell you the AJ is different in 2 areas at a glance. The thermal sealant on the transformers and the 2 coils as that will be a different panel. the Ba/BK I can't pick without comparing each part on a list
                  there is something strange with the info on Sj though, the BK they're quoting 50" panel sticker yet show 3 55" models
                  I'd say the BA/BK are 55", the AJ is 50"
                  • paulstef
                    • Dec 2013
                    • 724
                    I have the same fault, same board, 5336AM.
                    The chips are the R2A20250. Is there a way to find out which one is faulty?
                    • tw2005
                      • Oct 2011
                      • 6458
                      Should get a rough idea from simply determining which of the output pins are short with respect to gnd(vfg). then you should be able to guess which chip feeds that pin.
                      I've broken this diagram for you into the sectors and boxed in brown what are the panel connectors so you should have a good visual reference now.
                      I've got 2 5336 buffers shorted with only 1 chip, and
                      • paulstef
                        • Dec 2013
                        • 724
                        Awesome, thanks, I'll check them out this evening.
                        • paulstef
                          • Dec 2013
                          • 724
                          Thanks again. Exactly as you said. I had one defective chip, swapped it, everything works great.
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • Alicat
                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                            by Alicat
                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                            Model number is TH-50PZ85U
                            Power comes on and the red power light stays on solid.
                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                            I also hear a few clicks.
                            I also think my parents said there was a thunderstorm and the TV failed after that.
                            Section 6 in the service manual talks about power and no screen,...
                            10-30-2024, 10:09 AM
                          • nick31
                            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                            by nick31
                            My Oct 2012 panny plasma quit working yesterday.
                            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                            04-21-2021, 09:56 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                            Having said that I come to the gist of my post on the forum as the title suggests.
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • Biruslapio
                            Panasonic P58V11B 8 and 12 blinks error "fix"
                            by Biruslapio
                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                            04-13-2021, 07:13 AM
