Lenovo NM-B501 mainboard Type C charging stuck at 5V
  • vexarvf1s
    • Aug 2022
    • 26
    Looking for help.
    I have a Lenovo ET480 NM-B501 mainboard that I needed to replace the usb-C port on.
    After changing the port the computer works, but the DC-in from the type C power cord never goes above 5V.
    I took pictures before replacing the USB port on the mainboard and I am not seeing any componets missing.
  • vexarvf1s
    • Aug 2022
    • 26
    Re: Lenovo Type C charging stuck at 5V
    Using the following schematics to track down my problem:
    Originally posted by LenBios
    LENOVO THINKPAD T480 shematics
    https://www.badcaps.net/forum/showpo...88&postcount=3
    • vexarvf1s
      • Aug 2022
      • 26
      I am looking at the PD Controller chip as I am noticing USBC_VBUS20 and TBT_VBUS20 go to this chip.
      Below are the voltages I mesured.
      Does anyone know if these voltages look ok?
      PD Conntroller
      SN1701012RJTR (TPS65988)
      01 PP_HV2 5.1V
      02 __|
      03 VBUS2_ 4.88V/-1.7mv depending on port power is plugged into
      04 __|
      05 VIN_3V3 3.35V
      06 ADCIN1 3.016V
      07 LDO_3V3 3.32V
      08 ADCIN2 3.016V
      09 PP_HV1 5.12V
      10 __|
      11 VBUS1 -1.7mv/4.88V depending on port power is plugged into
      12 __|
      13 GPIO0
      14 GPIO1
      15 GPIO2
      16 GPIO5
      17 GPIO6
      18 GPIO7
      19 C1_CC1
      20 PP1_CABLE 5.12V VCC5M
      21 C1_CC2 1.3mV
      22 I2C1_SCL 3.3V
      23 I2C1_SDA 3.2V
      24 I2C1_IRQ# 0
      25 HPD2/GPIO3
      26 HPD2/GPIO4
      27 I2C2_SCL 3.29V
      28 I2C2_SDA 3.29V
      29 I2C2_IRQ# 3.29V
      30 LDO_1V8 1.79V VCC3_LDO_TBT_R
      31 SPI_MISO/GPIO8 3.3V
      32 SPI_MOSI/GPIO9 0
      33 SPI_CLK/GPIO10 0
      34 SPI_SS#/GPIO11 3.3V
      35 GPIO12 0
      36 GPIO13 -1.4mV
      37 GPIO14/PWM1 0
      38 GPIO15/PWM2 0
      39 HRRESET Ground
      40 CS_CC1 mV
      41 PP2_CABLE 5.12V VCC5M
      42 CS_CC2 1.65V
      43 PP_EXT1/GPIO16 0V
      44 PP_EXT2/GPIO17 3.32V
      45 C1_USB_P/GPIO18 -1.4mV
      46 C1_USB_N/GPIO19 -1.4mV
      47 C2_USB_P/GPIO20 -1.4mV
      48 C2_USB_N/GPIO21 -1.4mV
      • tomodachi
        • Apr 2012
        • 612
        • Turkey
        Sounds like a typical Thunderbolt issue. Find U15 and flash it with attached .bin file and try.
        Remember to make backup first.
          • 21948
          Please post your dumps in a new thread or this one in the bios requests section -> https://www.badcaps.net/forum/showthread.php?t=82558 .Then,post a link to it.
          • vexarvf1s
            • Aug 2022
            • 26
            SOLVED:
            Thank you very much for pointing me in the right direction tomodachi.
            Some legs of U15 had broken solder connections to the board.
            Reflowed the Winbond chip and the USB charging ports both work as expected.
            • tomodachi
              • Apr 2012
              • 612
              • Turkey
              Originally posted by vexarvf1s
              SOLVED:
              I m glad you solved it
              • t34v2
                • Mar 2014
                • 25
                • poland
                Re: Lenovo NM-B501 mainboard Type C charging stuck at 5V
                God bless you for this thread. I had same problem and i've spent few hours to figure out what is wrong. This thread nailed it. Thanks!
                • rbvndonh
                  • Mar 2021
                  • 162
                  • B
                  I correct solder joints and measured resistance to ground. It was same as other board with working 20V.
                  i dumped from OK board U15 chip and just reflash it to old board. Verification was OK, but board was still not working.
                  I tried to read dump to compare and it give errors during verify.
                  After soldering new W25Q80BV all went well and i have 20V ๐Ÿ˜€
