asus s400c bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need help to repair this original bios of ASUS S400C board id:S400CA REV.2.1.
    client told me that laptop becomes dead after updating os to windows 10. I measured voltages is present,there is 3v and 5v on the coil, and also there is 3.3v on power button and on the bios chip pin3 0v pin7 and pin8 have 2.9v.I already tried flashing the bios i found here in this forum, but still the same issue laptop is dead pressing power button nothing happens.but when i plugged the battery and plugged the charger charging light orange is present but pressing power button nothing happens.I have upload my original bios dump, can someone help me to fix this please
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: asus s400c bios needed
    Try Asus S400C fix first, if doesnt work try second if then not working then I dont think the BIOS is the issue here.
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Originally posted by romy2018
      i need help to repair this original bios of asus s400c board id:s400ca rev.2.1.
      Client told me that laptop becomes dead after updating os to windows 10. I measured voltages is present,there is 3v and 5v on the coil, and also there is 3.3v on power button and on the bios chip pin3 0v pin7 and pin8 have 2.9v.i already tried flashing the bios i found here in this forum, but still the same issue laptop is dead pressing power button nothing happens.but when i plugged the battery and plugged the charger charging light orange is present but pressing power button nothing happens.i have upload my original bios dump, can someone help me to fix this please
      bios
      • Romy2018
        • Sep 2018
        • 174
        • japan
        tried flashing bios above file still the same issue pressing the power button nothing happens.anyone please help on this
        • Romy2018
          • Sep 2018
          • 174
          • japan
          need help on this please, when i plugged on the bench lab supply is taking 0.03amps.
          • Romy2018
            • Sep 2018
            • 174
            • japan
            and i noticed when i plugged the charger the chip that has a marked JC EF is warm.
              • 21176
              The IC marked JC is a richtek RT8239B . Datasheet: https://cdn.badcaps-static.com/pdfs/...0d40ffc6d4.pdf
              http://*******/viewtopic.php?f=40&t=57074
              Boardview attatched .
              • Romy2018
                • Sep 2018
                • 174
                • japan
                thanks i cannot find the same ic can i replace this ic with RT8223MGQW?is it compatible?
                  • 21176
                  Do you mean you can`t find the IC on the board or online to buy ?
                  https://www.ebay.com/itm/3pcs-RT8239...p/401541431830
                  I don`t know if the RT8223MGQW is compatible,you`ll have to find the datasheet and compare the 2 IC`s .If in doubt get the original part .
                  • Romy2018
                    • Sep 2018
                    • 174
                    • japan
                    no i found online the same ic but the problem it takes time to deliver.client in a hurry i have onhand ic RT8223MGQW i just want to know if it is compatible replacement for this
                      • 21176
                      No, not compatible. The RT8223MGQW has 24 pins for a start .
                      • quezon
                        • Dec 2015
                        • 70
                        • Philippines
                        thanks
                        • grimacelord
                          ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                          by grimacelord
                          I have spent the last hour on this and I guess this is just over my head, so here I am.
                          I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                          The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                          Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                          by throwaway327
                          ASUS ROG Ally X - (Handheld Gaming PC)
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                          06-18-2025, 05:52 PM
                        • kodox
                          Asus ExpertBook B1400CB Bios Dump Needed
                          by kodox
                          need original bios dump, original bios has flashed by other technician before me.
                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                          unit info:
                          Model: Asus ExpertBook B1400CBA-0711A1235U
                          S/N: R6NXNZ006657238
                          CN: 7F6F
                          Mainboard Code: B1500CBA R2.1...
                          08-16-2025, 12:20 PM
                        • exerion5000
                          Bios Needed For Asus X515EA Pcb X415EA R2.0
                          by exerion5000
                          Asus X515EA_No Power_GD25B127D@SOIC8.rar
                          Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                          02-17-2025, 01:34 PM
