HP Elitebook 840 G6 bios password
  • ogre4273
    • Mar 2022
    • 57
    • N/A
    Re: HP Elitebook 840 G6 bios password
    Originally posted by hoaca388
    Only flash bios file (32MB)
    @hoaca388
    My bios chip is W25Q256JVEN and I have EZP2019, is my chip supported by that programmer? I will also use wson8 probe pogo pins to read it, is it also reliable to use? I don't have a soldering station. Thank you!
    • zak53
      • May 2018
      • 18
      • Z
      Re: RCUnlocker
      Hi all
      I have 840 G6 need some help PLS
      I tried the HPunlockTool. without success (won't turn ON)
      Thanks in advance
      • internautacesar
        • Aug 2016
        • 12
        • brazil
        can someone help me to remove the password
        • anhbanxoi
          • Sep 2021
          • 180
          • VN
          Originally posted by zak53
          Hi all
          Thanks in advance
          Try. Remember to go Security tab and restore default
          • anhbanxoi
            • Sep 2021
            • 180
            • VN
            Put 16MB file into HPUnlockerTool or RCUnlocker.
            • bluestar77
              • Apr 2015
              • 57
              • sudan
              #26
              Hi need help to clean this bios for 840 g6 with bios password
              • peste
                • Dec 2016
                • 13581
                • ROMANIA
                #27
                use PCUnlocker on the 16MB bios and unlock it yourself..
                • mrwab
                  Banned
                  • Jan 2014
                  • 83
                  • morocco
                  #28
                  try and replay
                  and poste motherboard code for other members
                  • ogre4273
                    • Mar 2022
                    • 57
                    • N/A
                    #29
                    Hello, I used wson8 probe pin to read a dump of my bios but I was too scared to continue because after putting the probe to the chip, the laptop lights turned on for a split second. So I booted again and thankfully the laptop works but after I shutdown to put the back case, the computer won't boot anymore so I did a power cycle and it works. The problem is, this is happening everytime I turned on the computer.
                    I decided to reset the bios to default. Restarted. Then while I was entering the bios again, the computer shuts down and now it won't boot with caps lock blinking. Is it possible that the bios is corrupted or there is a serious problem with the board?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12329
                      #30
                      Did you not remove the main battery and CMOS battery before doing it ?
                      ​https://www.badcaps.net/donate
                      • ogre4273
                        • Mar 2022
                        • 57
                        • N/A
                        #31
                        after removing the back cover, battery and cmos is the first thing I disconnected.
                        Is it possible that I corrupted the bios because the wson8 probe pin keeps on moving while the programmer (ch341a) is connected to the pc?
                        I volt-modded the ch341a to 3.3v and checked using a multimeter before doing any wson8 probing to the board.
                        another question..
                        Can I use the jumper pads or the gold pads beside the bios chip and use/cut the wson8 probe to act as a jumper wire?
                        Thank you very much.
                        • mrwab
                          Banned
                          • Jan 2014
                          • 83
                          • morocco
                          #32
                          another question..
                          yes you can use it to read and write bios chip then flash bios again with original files and try to power on
                          if work fine maybe bios not programmed correct
                          • ogre4273
                            • Mar 2022
                            • 57
                            • N/A
                            #33
                            that is the problem, i didn't read and write anything on the chip. I just put the wson8 probe pin and put back the case because I was nervous to try. (It is my first time)
                            The laptop works normally but everytime I shutdown then power on again the caps lock blinks and it takes too long to boot. So I decided to reset the bios to default and that is when the caps lock blinking issue becomes permanent. Even when I plugged in the charger and re-plug the battery it automatically power on then to caps blink again and again.
                            note: The charging led also blinks orange and white light.
                            Questions:
                            Did I short something while using the wson8 probe pin or I corrupted the bios because of it? (note that I didn't read nor flash anything on the chip)
                            is my chip W25Q256JVEN compatible with ch341a?
                            how can I repair my corrupted dump file using the BIOS official HP website? Will I use UEFITool to merge it?
                            Thanks for your help again.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12329
                              #34
                              Questions:
                              If you have a CH341A with a black board then voltage might be the problem, it has a default of 5 vol. Maybe it broke something.
                              • mrwab
                                Banned
                                • Jan 2014
                                • 83
                                • morocco
                                #35
                                Questions:
                                yes you can doi it with UEFITool or only with hxd or winhex or any hex editor
                                if you dont how to doi it upload original backup files i will make for you
                                • ogre4273
                                  • Mar 2022
                                  • 57
                                  • N/A
                                  #36
                                  Thanks for your reply.
                                  My chip is "JV" and I saw on datasheet that it requires 2.7v to 3.6v. So I think it is supported.
                                  Yes, I have a black ch341a and I volt-modded it (watched youtube videos many times) immediately after buying before trying. It reads 3.3v now on multimeter.
                                  Do you think I damaged something on the board or I just corrupted the bios because of the probe pins?
                                  • ogre4273
                                    • Mar 2022
                                    • 57
                                    • N/A
                                    #37
                                    Thank you!! tomorrow I'll read a dump.
                                    Last questions, those gold pads beside the bios chip are for jumpers right?
                                    and do I need to read a dump of the 16mb chip?
                                    there's an old version dump of my bios, can I flash it and downgrade?
                                    • ogre4273
                                      • Mar 2022
                                      • 57
                                      • N/A
                                      #38
                                      the solder on the solder pads has a small dents by the way, because of sharp probe pins. Is it possible that the problem comes from this? and I need to resolder the pads?
                                      • yuan22231
                                        • May 2022
                                        • 17
                                        • Philippines
                                        #39
                                        anyone pls help me to fix this error al try many bin files but after the installation of windows and connect to the internet the msg will be pup up ..
                                        and the windows is automatic shootdown..
                                        DEviceFreeze 23174
                                        this computer has been lost or stolen. your internet protocol address ip address has been recorded. please contact corporate security immediately ....
                                        https://www.4shared.com/photo/1ZdFKy..._840_g6_e.html
                                        https://www.4shared.com/photo/32vsfnRrea/hp_840_g6.html
                                        https://www.4shared.com/file/GoHswu7..._unlocked.html bin fil..
                                        • ogre4273
                                          • Mar 2022
                                          • 57
                                          • N/A
                                          #40
                                          DEviceFreeze 23174
                                          that is a computrace problem, send me the dump file of the bios chip. Both 32mb and 16mb. I'll try to help you.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
