Samsung PS-42C455 no picture
  • PowerAmpFreak
    • 982
    • Sweden
    #61
    Re: Samsung PS-42C455 no picture
    Datasheet for the RJP30E2 IGBT:
    https://cdn.badcaps-static.com/pdfs/...55f488a3d2.pdf
    • PowerAmpFreak
      • 982
      • Sweden
      #62
      Originally posted by JonathanAnon
      There is an RJP30E2 761082 on the board also, which I assume is the PNP version of this FET, and it measures 0.54v across it's source and drain pins on diode test..
      Did you remove both of them and measure out of circuit?
      There should be no difference between the two RJP's.
      IF you're measuring between collector and emitter (since it's an IGBT) on board, it's natural to have other readings since there are other components in parallell and interfere with your measurements.
        There are no P-IGBTs in any plasma display technology that I'm aware of. They cost at least twice as much so the equivalent circuit is implemented with N-type only.
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          #64
          Originally posted by PowerAmpFreak
          Did you remove both of them and measure out of circuit?There should be no difference between the two RJP's.
          Yeah I took two of them out of circuit and that was a bit of a job. They were not the type with the three pins inline (as in the PDF file above). They were the one with the gate pin forward. I managed to get them out and back in without breaking, but it was tricky. But no combination of any of the boards seems to change the behaviour of the LED on the logic board or hold the Va and Vs up at proper voltage (as both always drop).
          I took this picture of the chips BEFORE removing them.. Looks fairly sloppy, I'm wondering did somebody else have a shot at it before?
          I'm working my way back through my printouts / manuals etc. I'm gonna start from scratch with it again and give it one more shot.. I'll report back soon.
            That forward pin is most likely the drain.
            The Vs/Va will shut down on this model without proper sustain operation.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              #66
              Originally posted by tom66
              That forward pin is most likely the drain. The Vs/Va will shut down on this model without proper sustain operation.
              By the time I got the chip out of the heatsink, the leads were all pointing in different direction.. :-)
              I agree with what you're saying about the Vs/Va. In Yong's book on LCD Repair he suggests putting a bulb across the B+ line as a test load, to help to see if the problem is isolated to the PSU or whether problems are being caused by faults further down the chain. I wonder would putting a 100W bulb across the large voltage be enough to keep it up.... This would at least confirm to me that the PSU rails are not shutting down because of an issue on the PSU itself..
                No, it's the control board shutting it down. It'll do this when either Y-main or X-main are faulty on this chassis.
                The PSU is most likely fine.
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  #68
                  I've checked every component on the X buffer boards (both left and right) and it seems fine.. I can get the Y Sus and Y-buffer from the UK pretty cheap so I'm gonna get these and work from there..
                  • JonathanAnon
                    • Jul 2012
                    • 457
                    • Ireland
                    #69
                    Boards arrived today... and
                    They worked!!.. had a slight issue with a few lines across the screen, but by reseating the cables to the x-buffer board (which I learned last week from Damon Morrow's book) it came right again..
                    Thanks guys..
                    • pete_the_geek
                      • Jan 2011
                      • 20
                      #70
                      Glad you fixed it! That is a really, really strange issue - I have never heard of that before.
                      For resetting the EEPROM you can usually go into the service menu and select Factory Reset.
                      Hi Tom, I know it's an old thread but I just sorted a PS42C450 with exactly the same fault, this thread helped me solve it. 2xRJH30E2 on XSUS short, replaced but still no joy no bang and issue of smoke lol. However proble was traced to s/c cap under silicon on YBUFFER. Never had this before, wondering in other cases if these caps can go short to kill the XSUS and then fry to o/c ?
                        09-07-2024, 05:50 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Dodgethis
                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                        by Dodgethis
                        Hello all,
                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                        09-11-2024, 07:39 AM
