pioneer plasma PDP-435PE
Re: pioneer plasma PDP-435PE
The TV uses the chimney effect to keep itself cool: the cool air enters the bottom and exits the top due to convection (hot air rises.) The exiting air is hot, the TV creates a temperature differential. The fan assists with the moving of air through the set. That's why almost all of the heatsinks are mounted vertically.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
It should suck air in from the bottom and blow it out the top.
The TV uses the chimney effect to keep itself cool: the hot air enters the bottom and exits the top due to convection (hot air rises.) The fan assists this. That's why almost all of the heatsinks are mounted vertically.as the screen appears to have a bleed..several ccfl bad & shitty vestel board seems to have a fault..anyways back to normality for a while..thx guys
For all. I came across this very handy field service guide for Pioneer Plasma TVs.Comment
av had this tv 5 week was about buy a new MR box cuz had it given me but came across this forum and fixed it lol the guy who give it me is kicking himself now lolComment
Hello Everybody,
Just purchased myself an PDP-435PE panel with PDP-R05FE receiver. The guy told me the receiver was broken. Not sure if that is correct.
When I connect everything the red led on the panel is burning and the green and red led on the receiver are burning. No flashing of the leds. In one of the manuals I read this means there is something wrong with the receiver. In the manual of the receiver is a table (page 182) which suggests it is in "trap switch operation" I've checked the switch and it works fine.
I've tried to go to service mode but... My remote doesn't have an "Display" button (axd1491). Don't know how to enter it.
I hoped to be able to use only the panel. Just put the video in trough the DVI connector. Audio goes to my home system. Sadly this doesn't work according to the service manual of the panel.
Anybody any suggestions where to look in the receiver?Comment
With an programmable logitech remote I was able to get the system in service mode. At least i guess. The receiver gives a clic, the panel led goes to green and a few pixels on the screen (right top corner) light up. Hitting the power button on the remote gives me another click and the led on the panel turns on to red again.
After this I connected the dvi output of the receiver with an dvi-hdmi connector to my TV. When I put the receiver in service mode I get some scrolling blocks on the right side of the screen.
https://www.dropbox.com/s/3s2osbsbik...14.35.mp4?dl=0
anybody any suggestions?Comment
And the pixels on the panel:
https://www.dropbox.com/s/9nxblorjqy...02.49.mp4?dl=0Comment
There's something wrong with the X- or Y- panel drivers, but it is hard to say what, unfortunately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It is possible to use the Panel without the Receiver.
https://www.electro-tech-online.com/...needed.151212/
Hope this helps.Comment
Thanks for the responses. So I guess I first have to find the error in the panel. After that I'll start building the serial device to connect my laptop to the tv. I already planned to use it only trough HDMI. Glad to hear it is possible.Comment
by RatherLoopyI have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...-
Channel: Troubleshooting Audio Equipment
by pixelcapHello out there in Badcap land.
I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
Thank you
Pixelcap... -
by pulper111Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...-
Have a colleagues Pioneer VSX-3300, it wont power on, hasnt for a number of years, but just now trying to figure out what's going on with it.
It has 120V input and I have followed that 120V to a small board that appears to have a small transformer and a relay among a few other components I dont think the relay is changing state which I believe turns on the receiver, but this is all speculation.....
I have downloaded the repair guide, which I have attached to this post, but I am having a hard time following it.... Can someone please offer any advice on what to check?...-
by wolf1976hi i have a receiver that is destroyed from the overvoltage i guess
my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
the motor fan has not label
i have an other receiver operational
In your opinion can i measure the voltage at the output ?
what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
thanks in advance... - Loading...
- No more items.
