Panasonic Plasma TX-P50Gt30E with sparkles, brightness problem
  • DerD
    • Feb 2020
    • 7
    • DE
    I have build up again a defective SC-board TNPA5335 with all! IGBTs and several drivers and other components, after incomplete 6 blink repair and further issues. Finally I got the board almost to work again, running now at least for some minutes without shorting down.
    Anyway, something is still wrong, I guess but not 100% sure that it is on the SC-board.
    Latest step before now was sparkling all over the screen, then Q16820 was replaced and situation now is this. Also to say that Q661, IC921 and other parts for Vad have been replaced too, not only Q401-3 and Q421-3 as usual.
    As said, set is running up without failure mode and screen appears. Upper half is extremely bad, but also light sparkling can be seen on bottom part plus brightness problem, see pictures for test patterns. Strange to me all patterns show the problem except clear colours (RGB). See blue and also color bar.
    Vad (200V) and Vscn (147V) looking good for me.
    I did some scope testing for Vscn, but found nothing strange, but I'm not expert in that and may oversee something.
    Needless to say that i checked all components that seems relevant to me, twice.
    Any help to identify the defect is welcome. It might be not SC-board, but I have no idea what else it could be.
    regards,
    Dieter
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Panasonic Plasma TX-P50Gt30E with sparkles, brightness problem
    Is photo 5 showing a sustain problem (SS board)
    • DerD
      • Feb 2020
      • 7
      • DE
      I think, photo 5 is accumulation of effects. I never would say it cannot be SS board, but what make you think that? And maybe which part? I checked the board and have not found any defect.
      Visual failures are all horizontal. And, this is maybe not clear visible in attached pictures, the pixels are randomly fully bright, not any halftone. Like all sub-fields are addressed., although this should not be the case. Can be seen best in 3r picture, or 4th.
      • Lintesir
        Panasonic P42S30 Plasma - Pink sparkles
        by Lintesir
        My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
        There is about a 5cm high region at the top without any sparkles,...
        07-26-2024, 03:16 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • Nirrain
        Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
        by Nirrain
        I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
        I've tried to change VSUS to high but it made the issue even worse so changed it back.
        However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
        When turned on the green LED flashes 6 times and then stays on continously....
        07-09-2021, 02:38 AM
