Panasonic Toughbook CF-H2 bios PLZ
  • medinfo
    • May 2016
    • 331
    • Morocco
    • 21874
    Re: Panasonic Toughbook CF-H2 bios PLZ
    This may help,read the whole thread.
    https://www.ghostlyhaks.com/forum/ro...oughbook-cf-h2
    • phuongnt
      • Dec 2018
      • 1
      • Vietnam
      This is a dump reading from working cf-h2 mk3 I think (CF-H2Pxxx)
      • crisx24ro
        • Feb 2019
        • 2
        • Romania
        need bios for CF-H2 Mk2 CF-h2fREBEDE
        thanks,
        • samirinfo
          • Mar 2020
          • 54
          • oran
          Test this
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • eukal
            Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
            by eukal
            Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
            I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
            I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
            I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
            07-01-2023, 01:00 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
