Need Bios hp mini 210
  • reizal
    • Oct 2014
    • 111
    • aceh
    someone have a bios hp mini 210 for spi flash with ezp2013
    Hidup yang benar2 membosankan.. hek that bak mita peng
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    Re: Need Bios hp mini 210
    this may help you
    • reizal
      • Oct 2014
      • 111
      • aceh
      You have REV.F bro, i try with REV.G no display huhuuu
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        try this bro, good luck
        • khaahk
          • Dec 2013
          • 809
          • Estonia
          There are numerous versions of HP mini 210. Give board marking or ending of the model. 210-xxxxxx
          • reizal
            • Oct 2014
            • 111
            • aceh
            HP mini 210-1073TU
            • khaahk
              • Dec 2013
              • 809
              • Estonia
              quanta NM6 should be the platform. From a chinese site:
              • reizal
                • Oct 2014
                • 111
                • aceh
                Thank U, but still no display,
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  do you have DC bench power supply?
                  http://www.berniaga.com/ATTEN+APS300...A-17819410.htm
                  on many case for me if stuck on 0.8A-0.9A look like bios problem
                  some times you should change the IC and reprograme it
                  • khaahk
                    • Dec 2013
                    • 809
                    • Estonia
                    Maybe not bios problem...
                    • reizal
                      • Oct 2014
                      • 111
                      • aceh
                      the problem occurs when the update bios, before bios update laptop normal, after update no display, because bios update when the process is slow and that had a laptop to turn it off, then turn it on again the laptop no display, heheee
                      • dspok
                        • Jan 2014
                        • 553
                        • Nepal
                        can you give me service tag?
                        • techman1025
                          • Jun 2014
                          • 497
                          Hi
                          The problem an't the bios ..if the last file uploaded didn't work and i just check that file from the newest update from hp for your exact model they are exact no different.... So do you have external display? did you force it by unplugging internal cable..use flash light do you see any data on screen if yes then back light is out ...check display switch ....voltage on pin one of inverter ? whats is it .
                          Techman1025
                          • reizal
                            • Oct 2014
                            • 111
                            • aceh
                            problem solved..
                            I keep the laptop was 2 days and just now I turn on the laptop is already on LOL really weird,
                            Thank For All
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              selamat bro!
                              congrat bro!
                              you lucky man
                              • reizal
                                • Oct 2014
                                • 111
                                • aceh
                                Originally posted by meritosari
                                selamat bro!
                                congrat bro!
                                you lucky man
                                thank you bang
                                • ahmedpc75
                                  • Dec 2014
                                  • 3
                                  • maroc
                                  hello
                                  i need bios for hp mini 110 -4117sk pls
                                  • khaahk
                                    • Dec 2013
                                    • 809
                                    • Estonia
                                    1. Download:
                                    http://ftp.hp.com/pub/softpaq/sp60501-61000/sp60935.exe
                                    2. Unpack (7zip)
                                    3. Use phoenix tool 2.50 to open (decrypts), you got the bin file.
                                    4. Use HP Dmi tools to insert sn and other numbers if needed.
                                    • cesargarzon
                                      • Aug 2017
                                      • 3
                                      • Colombia
                                      Muchísimas gracias me sirvió !!!
                                      • kiwil baraa beree
                                        • Feb 2017
                                        • 5
                                        • indonesia
                                        pleace bios hp mini 210-1006tu
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • abhorsen
                                          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                          by abhorsen
                                          Hey guys,
                                          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                          07-06-2023, 10:22 AM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                        • AkaBukai
                                          Is it okay to flash stock bios onto the motherboard's BIOS?
                                          by AkaBukai
                                          Hi there,
                                          I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                          The little LED on the power button is flashing slowly and nothing happen.
                                          This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                          So I decided to flash the BIOS using a cheap programmer.
                                          And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                          I also...
                                          12-19-2024, 12:15 PM
                                        • James Jackson
                                          Panasonic CF-20G0247VM BIOS Bad Flash Help
                                          by James Jackson
                                          I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                                          Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                                          05-01-2025, 11:28 AM
