Samsung LN32A550 P3F
  • Kokonut09
    • May 2012
    • 15
    I just picked up this LCD TV and the symptoms are as follows.
    -Press power button
    -sound comes on
    -TV back light comes on for about a second or two
    -TV goes black, power indicator is dark
    -but! I press the power button once more, and plays the shutting down sound and red standby light comes on.
    I did a quick scan of the power board and inverter board for bad caps but didn't find any that looked physically bad.
    I was told that It could either be a bad inverter board, or a bad main board.
    Any suggestions would be greatly appreciated.
    I'll post pictures of the boards tomorrow.
    Thanks.
    Re: Samsung LN32A550 P3F
    Samsung has the odd behavior of lighting the LED in standby and turning it off while running. So, it appears the TV is turning on and off normally, but the backlight is disappearing - this is known as "two seconds to black".
    Causes include:
    - bad caps
    - bad transformers (likely)
    - bad CCFLs
    I highlighted bad transformers as Samsung TVs of this generation used a +24V supply and Darfon inverters (I think) which often fail. It is repairable by replacing the transformer.
    • Kokonut09
      • May 2012
      • 15
      Alright cool, how do I go about testing the transformer? I saw that you check in ohms, but when I tried that, I did not get any readings.
      I'll post a picture of the inverter board when I get home today.
        With a picture, we can suggest where to test... it's different for every transformer. Most will measure the same. Bad ones will measure values off by more than 3% either way.
        • Kokonut09
          • May 2012
          • 15
          Here we go, I hope these pictures turned out alright, I added pictures of the power board, not sure why, just in case?
            Test between these pairs of red marks.
            All should measure the same or nearly the same.
            Use the 20000 ohm (20k ohm) range.
            • Kokonut09
              • May 2012
              • 15
              First transformer
              1848/1826
              Second
              1851/1883
              Third
              1846/1826
              Fourth
              1823/1802
                The average resistance is 1838 ohms and the allowable deviation is 55 ohms either way, so I think your transformers are okay.
                Next step, are there any fuses on the inverter board?
                • Kokonut09
                  • May 2012
                  • 15
                  Yes, there is 1 fuse on the bottom left in the picture you pointed on the transformers on. 125V/8A
                  • Kokonut09
                    • May 2012
                    • 15
                    I checked the fuses on the inverted board and power board and they checked out fine. I unplugged the inverted board and its showing the same symptoms.( minus the fact that the back lights don't come on) do you think that I should just go ahead and replace the inverted board?
                    • Kokonut09
                      • May 2012
                      • 15
                      Something else that i noticed. The blue glow on the tv when sitting idle turns off when the TV turns "on" and when I turn the TV off, the blue glow comes back.
                        ...The screen glows when the TV is on?
                        • Kokonut09
                          • May 2012
                          • 15
                          When I press the power button the TV glows for 2 seconds then goes black. What I was referring to was the little blue light Accent that's under the Samsung logo. I apologies for the miscommunication.
                          • richpart
                            • May 2012
                            • 42
                            Samsung's service site has these listed as a common failure. They dry up meaning they may not look physically bad or bubbled up.
                            Symptom:**The*TV*takes*longer*to*power*on*than*normal.**You*may*hear*several*clicks*while*the*TV*attempts*to*power*on.
                            Cause:*The*electrolytic*in*the*capacitors*on*the*power*supply*board*over*time*will*dry*out*causing*the*power*supply*to*shut*down*durig*its*initial*power*on*cycle.
                            Cure:*Refer*to*the*capacitor*cross*reference*guide*below*for*the*list*of*the*capacitors*that*should*be*replaced.
                            TV Model*
                            Side Label version*
                            Capacitor for Service*
                            Location
                            Spec
                            Part Number
                            LN32A550P3F
                            SQ01, SS02, AA03
                            CB852
                            25V 1000uF
                            BN81-02020A
                            CM851,CM852
                            35V 1000uF
                            BN81-03142A
                            CM853,CM858
                            25V 1000uF
                            BN81-02020A
                            CM859
                            25V 470uF
                            BN81-03132A
                            I'm also seeing a firmware update and downloading it for you as well. You will have to pm me with an email address for me to send all 3 files. They are too large to upload here based on the site limits. There is a bulletin, a firmware update and power supply diagram.
                            • richpart
                              • May 2012
                              • 42
                              The bulletin shows CM861 a blue 2200uf 10V as being the largest culprit here.
                              • Kokonut09
                                • May 2012
                                • 15
                                I replaced the Inverter board but nothing changed. Screen glows for a couple seconds and shuts off. I managed to push the source button to find my xbox, and there is still sound. I volume works as well.
                                richpart, I Dont see capacitor CM861 on my board.
                                • Kokonut09
                                  • May 2012
                                  • 15
                                  Im gonna replace the caps and see what happens
                                    So far I did not see any reports on the voltage readings from the power supply board.
                                    I see that the power supply board has PFC Voltage booster, what DC voltage do you get on the large 450VDC cap when the TV is OFF and when the TV is ON?
                                    do get steady 24VDC at the inverter board?
                                    • Kokonut09
                                      • May 2012
                                      • 15
                                      I'll check when i get home tonight. But i am getting 23.87V or so on the inverter board
                                      • Kokonut09
                                        • May 2012
                                        • 15
                                        Not exactly sure how to test it. All i did was touch red multimeter line to the positive side and got a reading of 220V on and 6.8V when its off. And you were talking about this cap correct?
                                        And the inverter board gets 24.48 V.
                                        I appreciate all the help thus far.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          09-07-2024, 05:50 AM
