Hp 250 g5
  • dylen
    • May 2017
    • 173
    • Mauritius
    Hp 250 g5
    Hi everybody,I am in great despair about a laptop HP 250 G5 which wont turn on.When power button is pressed, power led comes out, fan spin for 5-6 seconds and stop,power led also cuts off, only the led for charger in remains on.
    May be its a bad bios, as there is 3 volts on the bios chip.
    Please can some one send me a working bios bin file.Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp 250 g5
    M/B Part No???? Is it D702P??
    • dylen
      • May 2017
      • 173
      • Mauritius
      Re: Hp 250 g5
      Hi, i will check it @ home, its a core i5 with no discreet graphic and 4gb ddr3.
      • dylen
        • May 2017
        • 173
        • Mauritius
        Re: Hp 250 g5
        M/B part No: bdl50 LA-D703P - REV3.0
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3622
          • slovakia
          Re: Hp 250 g5
          check all powerswitched rails for short or no woltage
          • dylen
            • May 2017
            • 173
            • Mauritius
            Re: Hp 250 g5
            1 Recap having not come across any 5 volt on the mb, 19v & 3.3 volt were present.Where should i look for the 5v, as i dont have schematic.
            • dylen
              • May 2017
              • 173
              • Mauritius
              Re: Hp 250 g5
              Any schematic for the HP 250 G5? please.
              Here is the bios dump
              • foufou0238
                • May 2017
                • 10
                • france
                Re: Hp 250 g5
                hello ,
                in attachement you will see 3 files of bios dump original one from HP you can give test and put replay .
                good luck
                • dylen
                  • May 2017
                  • 173
                  • Mauritius
                  Re: Hp 250 g5
                  Thanks, will try and let you know.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: Hp 250 g5
                    Backup & Try. 100% working dump
                    Its easier to help when you give complete info
                    • dylen
                      • May 2017
                      • 173
                      • Mauritius
                      Re: Hp 250 g5
                      Many thanks mcplslg123, will tryand revert back
                      • dylen
                        • May 2017
                        • 173
                        • Mauritius
                        Re: Hp 250 g5
                        No luck with bios flash, now board on & off every 5-6 seconds.
                        • dylen
                          • May 2017
                          • 173
                          • Mauritius
                          Re: Hp 250 g5
                          Pq 13 pin 1,2,3,5,6,7,8 grounded, Is this normal
                          • dylen
                            • May 2017
                            • 173
                            • Mauritius
                            Re: Hp 250 g5
                            Fault on chip 8A 3G B59, can someome give me the exact reference
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              Re: Hp 250 g5
                              Maybe this one
                              https://cdn.badcaps-static.com/pdfs/...6efd1981b0.pdf
                              https://www.aliexpress.com/item/RICH...3-8a98f9ae4f3d
                              • dylen
                                • May 2017
                                • 173
                                • Mauritius
                                Re: Hp 250 g5
                                Thanks, will order and try.
                                • NConstantinou
                                  • May 2017
                                  • 348
                                  • Cyprus
                                  Re: Hp 250 g5
                                  Check on charger there you should have 3.3 and 5v output.
                                  If not then possibly need to change charger is
                                  • saqersaleh
                                    • May 2017
                                    • 14
                                    • jordan
                                    Re: Hp 250 g5
                                    hp 15-ay032nx la-d703p rev 3.0 bios dump pls hlp...
                                    • deepak47
                                      • Jul 2017
                                      • 11
                                      • India
                                      Re: Hp 250 g5
                                      3.3 volt rail is shorted in my mb, after injecting voltage, nothing but pch is getting warmer, anyone will tell me that if cpu is really damaged?
                                      • Chieftain
                                        • May 2016
                                        • 72
                                        • Greece
                                        Re: Hp 250 g5
                                        Dump is fine.,,, it worked for me,, Thanks mate
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
