Hp 250 g5
  • dylen
    • May 2017
    • 173
    • Mauritius
    Hp 250 g5
    Hi everybody,I am in great despair about a laptop HP 250 G5 which wont turn on.When power button is pressed, power led comes out, fan spin for 5-6 seconds and stop,power led also cuts off, only the led for charger in remains on.
    May be its a bad bios, as there is 3 volts on the bios chip.
    Please can some one send me a working bios bin file.Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp 250 g5
    M/B Part No???? Is it D702P??
    • dylen
      • May 2017
      • 173
      • Mauritius
      Re: Hp 250 g5
      Hi, i will check it @ home, its a core i5 with no discreet graphic and 4gb ddr3.
      • dylen
        • May 2017
        • 173
        • Mauritius
        Re: Hp 250 g5
        M/B part No: bdl50 LA-D703P - REV3.0
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3634
          • slovakia
          Re: Hp 250 g5
          check all powerswitched rails for short or no woltage
          • dylen
            • May 2017
            • 173
            • Mauritius
            Re: Hp 250 g5
            1 Recap having not come across any 5 volt on the mb, 19v & 3.3 volt were present.Where should i look for the 5v, as i dont have schematic.
            • dylen
              • May 2017
              • 173
              • Mauritius
              Re: Hp 250 g5
              Any schematic for the HP 250 G5? please.
              Here is the bios dump
              • foufou0238
                • May 2017
                • 10
                • france
                Re: Hp 250 g5
                hello ,
                in attachement you will see 3 files of bios dump original one from HP you can give test and put replay .
                good luck
                • dylen
                  • May 2017
                  • 173
                  • Mauritius
                  Re: Hp 250 g5
                  Thanks, will try and let you know.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: Hp 250 g5
                    Backup & Try. 100% working dump
                    Its easier to help when you give complete info
                    • dylen
                      • May 2017
                      • 173
                      • Mauritius
                      Re: Hp 250 g5
                      Many thanks mcplslg123, will tryand revert back
                      • dylen
                        • May 2017
                        • 173
                        • Mauritius
                        Re: Hp 250 g5
                        No luck with bios flash, now board on & off every 5-6 seconds.
                        • dylen
                          • May 2017
                          • 173
                          • Mauritius
                          Re: Hp 250 g5
                          Pq 13 pin 1,2,3,5,6,7,8 grounded, Is this normal
                          • dylen
                            • May 2017
                            • 173
                            • Mauritius
                            Re: Hp 250 g5
                            Fault on chip 8A 3G B59, can someome give me the exact reference
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              Re: Hp 250 g5
                              Maybe this one
                              https://cdn.badcaps-static.com/pdfs/...6efd1981b0.pdf
                              https://www.aliexpress.com/item/RICH...3-8a98f9ae4f3d
                              • dylen
                                • May 2017
                                • 173
                                • Mauritius
                                Re: Hp 250 g5
                                Thanks, will order and try.
                                • NConstantinou
                                  • May 2017
                                  • 353
                                  • Cyprus
                                  Re: Hp 250 g5
                                  Check on charger there you should have 3.3 and 5v output.
                                  If not then possibly need to change charger is
                                  • saqersaleh
                                    • May 2017
                                    • 14
                                    • jordan
                                    Re: Hp 250 g5
                                    hp 15-ay032nx la-d703p rev 3.0 bios dump pls hlp...
                                    • deepak47
                                      • Jul 2017
                                      • 13
                                      • India
                                      Re: Hp 250 g5
                                      3.3 volt rail is shorted in my mb, after injecting voltage, nothing but pch is getting warmer, anyone will tell me that if cpu is really damaged?
                                      • Chieftain
                                        • May 2016
                                        • 72
                                        • Greece
                                        Re: Hp 250 g5
                                        Dump is fine.,,, it worked for me,, Thanks mate
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          Yesterday, 05:52 PM
