searching for ASUS Prime X570 PRO bios dump
  • Bartoloni
    • Jul 2018
    • 140
    • Italy
    i have a board that shows only the "red" light on DRAM LED...
    the customer guarantees 100% that it happened after a BIOS update
    searching on ASUS site all the bios are not "complete" (33554432 bytes)
    this is the link to official downloads: https://www.asus.com/it/Motherboards...HelpDesk_BIOS/
    Can anyone help with this? its' possible to recreate a full binary from an original .CAP ?
    (i have not yet dumped the eeprom)
  • peste
    • Dec 2016
    • 13185
    • ROMANIA
    Re: searching for ASUS Prime X570 PRO bios dump
    post the original bios..
    • Bartoloni
      • Jul 2018
      • 140
      • Italy
      Thank you very much for your time Peste
      here the dumped original bios (the strange thing is that is 33555200 bytes ... i've used the TL866II+ that detect correctly the eeprom.. W25Q256JW )
      (removed "malformed" dump)
      • peste
        • Dec 2016
        • 13185
        • ROMANIA
        it's longer .. remove the bios chip from the motherboard, put it in the adapter and then read it .. or stick wires between the chip and the programmer, don't use the clip..
        • Bartoloni
          • Jul 2018
          • 140
          • Italy
          Just upgraded the XGECU software and TL866 firmware and now the reading is correct...
          here the dumped bios with a correct lenght:
          (i'm using wires directly on de-soldered eeprom)
          • lotas
            • Jan 2016
            • 4708
            • Russia
            It was possible to recover safely using "USB BIOS FlashBack"
            https://www.youtube.com/watch?v=FPyElZcsW6o
            And with such long wires, there may be errors when reading and writing, for this there is a special connector near the bios flash for dumping.
            And it was not necessary to solder flash.
            • Bartoloni
              • Jul 2018
              • 140
              • Italy
              This motherboard do not provide the ASUS flashback. (is not a feature and there is not the flashback button)
              i saw near the eeprom the TPM module connector... but.. is a TPM connector.. not sure it can be used to connect the programmer to the eeprom..
              as my first try i connected all the 8 wires directly to the eeprom ( directly on PCB without de-soldering the chip) but the TL866II+ was not able to recognize the chip. after that i desoldered it.
              (wires are longer because they was the same used to dump directly on the mainboard but i dumped the chip 3 times without any change on md5.. and i'm pretty sure was not corrupted.. also using my serials-reader a lot of infos are read correctly. www.wcn.it/BIOSdump2license.zip)
              • lotas
                • Jan 2016
                • 4708
                • Russia
                Bios from the Asus site is transferred from CAP to BIN.
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  But from asus site in bios you will lose SN, MAC, UUID. You need to edit dump.
                  • Bartoloni
                    • Jul 2018
                    • 140
                    • Italy
                    Oh WOW! thank you lotas! i never seen before the FD44 tool, very usefully
                    the dump need to be edited manually using an hexeditor?
                      • 21444
                      you can do. copy the block 84000 - 8405F
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        PX570PRO _fix
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          No, just copy from one window and paste it into another window and save.
                          • Bartoloni
                            • Jul 2018
                            • 140
                            • Italy
                            ohh thank you!!! you guys saved my day
                            • Bartoloni
                              • Jul 2018
                              • 140
                              • Italy
                              If i can ask... using what tool you was able to identify this address?
                              (sorry for boring you ... but i'm not a bios specialist and i'm very interested on understanding what "happens" on these eeproms)
                              (on the version provided by Iotas, at this address there are no data.. but FD44 tool can read correctly the MAC address and other data)
                                • 21444
                                Using HxD hex editor i searched for the word ASUSBKP
                                • Bartoloni
                                  • Jul 2018
                                  • 140
                                  • Italy
                                  Same thing, DRAM led lighted.... with your help i was able to obtain a flashable firmware starting from an old one.. the 2407 and with this, the PC started again (a firmware update for LED started also with a warning about "not shutdown PC" )... after reboot.. every is working (no idea what maximum bios release can be used without DRAM issues)
                                  • Bartoloni
                                    • Jul 2018
                                    • 140
                                    • Italy
                                    Looking at original bios dumped there are 2 address related to serial number:
                                    (maybe it's necessary to find BSA ? )
                                    • Ovi91
                                      • Sep 2022
                                      • 16
                                      I need a bios which supports Ryzen 5600 ,I red red light led on CPU?for Asus Prime x570-pro.Thank you.
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
                                      • Habble7
                                        I need a BIOS dump for the Samsung S49CG934SU monitor
                                        by Habble7
                                        The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                        Suspected Cause:
                                        I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • DynaxSC
                                        Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                        by DynaxSC
                                        I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                        The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                        Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                        Usually on ASUS boards it worked...
                                        06-14-2024, 03:49 PM
                                      • haitham sharabati
                                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                        by haitham sharabati
                                        Hello engineers 😀,
                                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                        🔧 Device Info:
                                        - Model: HP 15-da2007ne
                                        - Product Number: 8XF55EA#ABV
                                        - Serial Number: CND0338P0D
                                        - CPU: Intel Celeron N4000
                                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                        💀 Problem:😅
                                        - Device shows “Administrator Password”...
                                        08-07-2025, 04:54 AM
                                      • Citymin
                                        NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                        by Citymin
                                        My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                        The charging red LED lights up, but the charging screen doesn't show any indication.
                                        When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                        (I've tried removing the battery and resetting the device, but the issue persists.)
                                        NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                        PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                        S/N : 5RNK9FFT70...
                                        08-05-2025, 05:12 AM
