Lenovo E540 - BIOS Supervisor Password
  • WanderingMonk
    • Feb 2021
    • 4
    • Dominican Republic
    I have been looking all over the internet for a solution to this problem. I bought this laptop and the seller didn't even specify it had a BIOS password which is just frustrating because as a software developer, I must utilize virtual machines in order to generate test environments for my projects and I can't due to the VT-x feature being disabled in the BIOS Setup Utility and on top of that, said settings are locked behind a BIOS supervisor password as stated in the thread's title.
    Can anyone help me through this issue? I would appreciate it a lot. Thank you for reading.
  • peste
    • Dec 2016
    • 13809
    • ROMANIA
    Re: Lenovo E540 - BIOS Supervisor Password
    Originally posted by WanderingMonk
    I have been looking all over the internet for a solution to this problem. I bought this laptop and the seller didn't even specify it had a BIOS password which is just frustrating because as a software developer, I must utilize virtual machines in order to generate test environments for my projects and I can't due to the VT-x feature being disabled in the BIOS Setup Utility and on top of that said settings locked behind a BIOS supervisor password.
    post the backup of the bios and someone will try to help you.
    • WanderingMonk
      • Feb 2021
      • 4
      Done, it is now in the original post! Thank you for the information, I hope someone can help me with this issue.
        • 22170
        The password is stored in a small chip P24S08,24RF08 or similar. You can short 2 pins together to remove it
        https://www.allservice.ro/forum/viewtopic.php?t=52
        https://www.allservice.ro/forum/images/e540.jpg
        1. Turn on the laptop.
        2. As soon as the display turns on, short pins 5 and 6 and keep them shorted.
        3. Hit F1 to open BIOS.
        4. Wait no more than 2-3 seconds and release short. If you wait too long, it's over.
        5. BIOS opens up, you are in.
        6. Go to SVP password, set up a new one and Save&Exit with F10.
        • WanderingMonk
          • Feb 2021
          • 4
          Thank you for the very useful information! I will now proceed to unlock my SVP in order to activate Intel's VT-x feature.
          Thank you for the quick response and solution!
          • Sunny tech 23
            • May 2019
            • 9
            • Nigeria
            Asking of current password thank u sir
              • 22170
              the current password should be blank if youve cleared it properly .
              • baaligoga
                Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                by baaligoga
                Good day, everyone!
                I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                05-20-2023, 09:48 AM
              • tlindi
                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                by tlindi
                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                >Read BIOS guides, methods, resources and tools
                Ack
                >Try the method at BIOS guides, methods, resources and tools before requesting help
                Ack
                >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                01-30-2025, 04:26 AM
              • RMDUiFT
                Should I buy a Lenovo Thinkpad E495 with bios password?
                by RMDUiFT
                Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                I have a few questions:
                • If I would buy this laptop and have
                08-25-2024, 09:00 AM
              • badzymandiaz
                Thinkpad P14s Gen 4, BIOS Supervisor Password
                by badzymandiaz
                I have a laptop that was purchased second-hand, and I am able to boot Windows on and extract the BIOS dump (ONLY the BIOS region, I was unable to dump anything else due to an FCERR I received trying to dump the other regions) and use normally. However, because the BIOS is locked with a supervisor password, I am unable to use anything else except for Windows, and it has also disabled some hardware features of the laptop itself, such as the fingerprinting module, etc. that I really do wish to use.
                I have been digging around for nearly 2 weeks trying to find any mention of the same model...
                09-28-2025, 10:49 AM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
