acer e5-473g bios needed
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    hi everyone i need help on this acer aspire e5-473g A4WAB LA-C431P
    Rev: 1.0. i already tried flashed the main bios with the dump i got here in this forum but still the same issue turns on fan at full speed then goes off i cannot flashed the EC because it is name as NUVUTON i cannot find in my programmer minipro tl866cs. i have attached the original dump can someone fix this please
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: acer e5-473g bios needed
    anyone help on this please i notice u31 no voltage but on the main bios all voltages present i dont know how to select in programmer for this novuton ec chip because there is no option on miniprotl866cs
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Is it C431p or C341p???
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If it is later , then i have ec dump. You can flash on another chip(which probably supports on your programmer)
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          @thanks for the response mcplslg123 the board code is A4WAB LA-C341P my mistake above.it is possible i use ec winbond w25x20 chip? can you share also the working main bios for this model please
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Try this if not solve not bios problem.
            • Romulo
              • Nov 2016
              • 484
              • Philippines
              thanks imaranromi i will try that and feedback i need also ec and can i use winbond w25x20 chip to replace nuvuton 39425? because my programmer not supported with this ec chip
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Can you share pics ec chip?
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  ok here it is the ec chip novuton 39425
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    This chip is not ec.check schematic page 9 and search u31 you know what is.
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      that is the U31 in the board imranromi and schematic you upload it is NCT3942S SOP 8P novuton
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        I know i think is not ec bios if i not wrong ec bios not 4pins ground 1 pin ground check u31
                        5.6.7.8. pin ground no scl ,no sda.
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          @imranromi there is no other u31 on the board that is the only u31 and i cannot find any ec chip rather than that novuton it is 8pin chip and im sure this is the ec my only problem is cannot program because programmer not supported there is no voltage on each pin of this chip but in the bios main chip voltage present and also 3.3 and 5v ALW is present.can someone help me on this
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Try.Good luck bro.
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              thanks mcplslg123 can i use winbond w25x20 for ec?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                winbond w25x20 IS 256KB and the ec for this acer is 128kb. So i doubt whether you can use 25x20. I'll suggest 25x10 instead or any other 128kb chip.
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  128kb file is ENE KB9022 NOT novuton.
                                  • Romulo
                                    • Nov 2016
                                    • 484
                                    • Philippines
                                    thanks mcplslg123 ill try to find 128kb chip you are right ill try to find 25x10 winbond. at imranromi i already post clear image the name write on the chip is novuton
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Hmm, I think Imranromi is right. The EC i have posted should be for Ene90xx.
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        This is a common problem with this laptop, I have 2 boards (same board code as you) with this same problem. I'm guessing CPU replacement will fix the problem.
                                        Did other guys already tried replacing the CPU on this board and fixed the issue?
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                        • NecroFlex
                                          Acer Aspire 1 A115-32-C28P BIOS needed please
                                          by NecroFlex
                                          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                          02-11-2025, 08:51 AM
                                        • Loli Popu
                                          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 03:28 AM
                                        • drux
                                          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                          by drux
                                          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                          These models have AMI/Aptio BIOS.
                                          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                          11-03-2024, 01:18 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
