Probook 450g3 bios
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Probook 450g3 bios
    Please i need someone to help me to reset password for this dump.
    Attached original bios and hp site update bios.
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: Probook 450g3 bios
    Anyone?????
      • 20609
      The flash descriptor is missing from your bios backup. Try this one
      • bachir2004
        • Feb 2015
        • 437
        • maroc
        Originally posted by smdflea
        the flash descriptor is missing from your bios backup. Try this one
        this is the point,no file descriptor,i have done other possibilities but i have no display.was trying to remove bios password.found an other one,made bios backup with universal bios toolkit same thing no flash descriptor.i am still stuck at this one.
          • 20609
          Hold down left + right arrow keys and power up, there may be a message then on screen about the flash descriptor being unlocked,then you can make a backup or flash the bios at post #3 with Flash Programming Tool.The flash descriptor will lock again at shutdown/reboot.If it doesn`t work use a bios programmer,desolder or use a sop8 clip .
          • sourcebf
            • Jul 2016
            • 431
            • N/A
            Try this..
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              bachir2004, have you tried other dumps in this forum?? May be your backup is not proper.
              • bachir2004
                • Feb 2015
                • 437
                • maroc
                I HAVE TRIED. I EVEN MADE BACKUP FROM AN OTHER MACHINE THEY ARE THE SAMEWITH NO DESCRIPTOR.EVEN HE METHOD SUGGESTED BY TECHMAN1025 IN THE THREAD BELOW LEADED TO NO DISPLAY.ANY ADVISE OR SUGGESETION WOULD BE WELCOME .
                https://www.badcaps.net/forum/showth...t=62477&page=2
                  • 20609
                  You can`t backup that part of the bios with universal bios toolkit ,because the flash descriptor part of the bios is locked. Try what i said at post #5 ,if that doesn`t work,try holding down the Win key and l + r buttons while powering up. If nothing works use a bios programmer ,flash the bios at post #3 or #6 .
                  • bachir2004
                    • Feb 2015
                    • 437
                    • maroc
                    First dump post #3 no display,second one post #6 only 7 blinks,machine does not power on.my original dump from locked machine was done by rt809f bios programmer.i am so confused,i have four other machines waiting.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Your backup is definitely not proper. I too use RT809F programmer but i never get such broken backup. Btw, You try this bios and post result.
                      • bachir2004
                        • Feb 2015
                        • 437
                        • maroc
                        Many thanks will try and reply.
                        • mikeybass
                          Dell 9010 MT BIOS Update Always Fails
                          by mikeybass
                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                          04-23-2025, 04:30 PM
                        • Soumana Sanou
                          ā€œHP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                          by Soumana Sanou
                          Hello,šŸ˜‡šŸ˜‡šŸ˜‡
                          I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                          šŸ”§ Model: HP ProBook 11 G2
                          šŸ“¦ Serial Number: 8CG72478MY
                          šŸ†” UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                          šŸ”’ BIOS Status: Locked with password
                          The laptop is no longer under warranty and HP refused to help me.
                          I’m looking for a custom SMC.bin file.
                          I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                          Thanks a lot for your help!šŸ™šŸ™šŸ™...
                          06-17-2025, 04:04 PM
                        • akwky
                          by akwky
                          Hi!
                          04-14-2025, 01:56 PM
                        • al3m0di
                          Update bios EFCN58WW to EFCN59WW
                          by al3m0di
                          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                          The BIOS version is EFCN58WW.
                          When I turn on the device, it displays the message:
                          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                          I've tried
                          07-29-2024, 10:32 AM
                        • YG007
                          Asus BIOS How To Reset To Default Settings?
                          by YG007
                          Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                          I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                          06-05-2023, 08:22 PM
