Dead Vestel 17IPS20 - MOSFET short circuited
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    yesterday, I have killed 17IPS20 23117579-27002042, by accidentally making short circuit on MOSFET Q211m while trying to measure coltage on its legs. According to the schematics I could find in the Internet Q211 is FQPF8N60C. Please have a look at the attached picture. I have short circuited Gate and Source. After this I don't even have StdBy voltages on the connector.
    What else could be potentially damaged so I can check before ordering replacement parts? I ask this because I couldn't find exact schematics for this particular revision. I believe it is revision 5 because there is a number on the PCB: 040313R5.
  • nomoresonys
    • 12310
    • U.S.
    Re: Dead Vestel 17IPS20 - MOSFET short circuited
    Why do you have two threads about the same tv?? we can plainly see the first thread, these double threads are frowned upon and they only shit up the boards and you still haven't posted ALL the pictures asked for in the first thread if you can't follow simple directions then HOW can anyone help you??
    • Askic
      • Sep 2018
      • 187
      • BIH
      Because the original problem is solved by replacing the board with another one.
      Here, I want to try to save this board and keep it as spare.
      I didn't post pictures of the broken TV in this thread, because I took its supply board (17IPS20 different version), MB (17MB82s) and LED chassis and installed in the other TV. So, there was no point to troubleshoot that further, because I assumed T-con was bad and I was right.
      I started another thread, because it's a different type of a problem on a different TV.
      • nomoresonys
        • 12310
        • U.S.
        Alright then, looks like you're in the clear, lol, well maybe it will keep someone else from double threading.
        • petehall347
          • Jan 2015
          • 4447
          • United Kingdom
          i believe its good practice to check gate drive resistors to save fets blowing again .
          • R_J
            • Jun 2012
            • 9610
            There is a source resistor next to the mosfet (R228?) it should be a low value 0.33~0.47Ω.
            If the mosfet shorted, it might have also opened that resistor. If it is open, check R242 and if it is open the ic is likely bad as well.
            • Askic
              • Sep 2018
              • 187
              • BIH
              Yes, there is a resistor R228 that should be 0.47Ω. This resistor is now open.
              There is also R242 (image nr 2), but it is steady 2.56 kΩ, so I'm not sure what to think of it.
              I have noticed also that two diodes D512 and D513 that are next to Q301 MOSFET are conducting in both directions (when multimeter is switched to diode checking. One direction of instrument leads displays 585 and other 595). The both diodes have the same behavior.
              It seems I don't have right 17ips20schematics because for R228 on this schematic is written 120R and in fact on the body of the resistor it can be read 0.47Ω. The same goes for R242
              • petehall347
                • Jan 2015
                • 4447
                • United Kingdom
                i guess you are checking in circuit ? if so lift one side of one or both and test again .
                • yokoono
                  • Apr 2010
                  • 510
                  You will not repair the power supply if you do not replace the pwm U202 controller (apart from all other related components).
                  • Askic
                    • Sep 2018
                    • 187
                    • BIH
                    Yokoono, can you please help a bit more. It is very hard to read what is written on U202. It seems to me: TD 1AD 6742HR SYD. Is that so? On the schematic I use there is no U202 under that number. There is SG6742HR. I believe I don't have appropriate schematics. Is that part TD1 AD important?
                    Thank you.
                    • nomoresonys
                      • 12310
                      • U.S.
                      It also won't work if one of those diodes is bad so lift a leg and check it out of circuit.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        In post #7, R217 just below U202 looks damaged?
                        U202 is an SG6742HR device
                        • R_J
                          • Jun 2012
                          • 9610
                          Yes the schematic is wrong for R228, the correct value is 0.47Ω in your case.
                          R242 should be 10Ω (marked 100)
                          When R228 goes open and the fet is shorted, aprox 300v is applied to R242 and the ic, you see what it did to R242, imagine how the ic handle it inside. The ic is damaged for sure. Also check R217 gate resistor, it might be damage also.
                          D512 & D513 are likely ok and have a resistor (R320) across them, which is likley a low value. (what is the value of R320?)
                          • Askic
                            • Sep 2018
                            • 187
                            • BIH
                            R217 shows about 33 kΩ, but this value slowly drifting up (like some condenser is charging), so it's dead also.
                            Value od R320 should be 0.33Ω (it's written on it) and when measuring, the instrument shows steady 0.6 Ω, so it's probably good. The diodes are good, I have check them by lifting legs out.
                            Ok, thank you guys, I'll see what are the delivery times when ordering from ebay and then decide what's next.
                            • R_J
                              • Jun 2012
                              • 9610
                              When measuring low ohm resistors, you need to take into consideration the meter lead resistance, short the leads together, what is the resistance? It could be 0.27Ω.
                              Lead resistance + resistor value = displayed value
                              • Askic
                                • Sep 2018
                                • 187
                                • BIH
                                Hello RJ, yes I have checked that. When leads are shorted, the instruments displays sometimes 0.1 and sometimes 0.2. That is why I wrote that R320 is most probably OK.
                                I really wonder what is the correct value of R217, according to the schematic it is also 10Ω.
                                • R_J
                                  • Jun 2012
                                  • 9610
                                  What is marked on the resistor? 100 = 10Ω; 101 = 100Ω, The datasheet for the ic lists a 100Ω
                                  • questore
                                    HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                                    by questore
                                    Hello everyone.
                                    Someone brought this poor hp in.
                                    All power rails had normal resistances so i turned it on. Instant power cutoff...
                                    First mosfet was shorted so replaced it...
                                    After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                                    After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                                    Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                                    08-25-2025, 10:09 AM
                                  • aaronkatrini
                                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                    by aaronkatrini
                                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                    - Put the card in my testing motherboard and start running Heaven benchmark
                                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                    - Put the...
                                    05-18-2025, 04:18 PM
                                  • jm942
                                    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                    by jm942
                                    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                    I did voltage injection on the cpu with 0.7V and i have a current...
                                    07-11-2024, 05:11 AM
                                  • joshAU
                                    Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                    by joshAU
                                    Hi all.
                                    This notebook was showing no signs of life.
                                    I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                    However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                    If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                    I tried replacing the MOSFET with a new one, but again no voltage on the...
                                    05-29-2024, 12:33 AM
                                  • pavithra_uk
                                    Optiplex 3050 Vcore Mosfet short
                                    by pavithra_uk
                                    it is 3+2 vrm
                                    vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
                                    gate drive chip (NCP81166) also gone.
                                    any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
                                    odd question:
                                    what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
                                    10-21-2025, 11:32 AM
