PANASONIC Th-p50g10 6 red blinks
  • cb007cb
    • Jan 2014
    • 51
    • usa
    Put the power cord in here 1 click 2 green lights on left and right board turn
    on fans go on for a few seconds then switch off.Then the 2 green lights slowly fade out!!6 red blinks.Any ideas thanks!
  • cb007cb
    • Jan 2014
    • 51
    • usa
    Re: PANASONIC TC-p50g10 6 red blinks
    tc not th!
    • tw2005
      • Oct 2011
      • 6458
      Re: PANASONIC Th-p50g10 6 red blinks
      I'd be thinking bad SC, seems to be a board that fails in these.
      https://www.badcaps.net/forum/attach...3&d=1396151881
      • cb007cb
        • Jan 2014
        • 51
        • usa
        Would the green light still go on if the board was bad?
          On the SC?
          The green light indicates no SOS6 (i.e. ERC floating voltage OK.)
          However this CAN change during operation causing SOS6 to fire.
          So - does the green light go out just before it shuts down?
          • tw2005
            • Oct 2011
            • 6458
            For a moment it could. Does it get real bright or dimmed and shutdown as soon as it is lit? Try this flowchart and see how you go.
            • cb007cb
              • Jan 2014
              • 51
              • usa
              It goes bright on both boards fans go on shut off real quick then the green lights slowly fade.
                Check TP_SOS6 on the SC board. What voltage do you get as it shuts down? I'm thinking an A board fault here misdetecting 6 blinks.
                • cb007cb
                  • Jan 2014
                  • 51
                  • usa
                  thanks tw will try that flow chart and see if it gives me the answer.
                  • cb007cb
                    • Jan 2014
                    • 51
                    • usa
                    thanks tom will try the voltage later before i go through the flow chart.
                    • cb007cb
                      • Jan 2014
                      • 51
                      • usa
                      thanks tom will try that later.
                      • cb007cb
                        • Jan 2014
                        • 51
                        • usa
                        Looks like its the A board service manual says no osd check lights which are good so it says A board.I then used flowchart from tw2005 after 2nd test i got 8 blinks which says A board! So between tom and sw i think you may have done your magic again thanks.........chris. Now have to find a board at good price!
                        • tw2005
                          • Oct 2011
                          • 6458
                          I'd still check TPSOS6 as TOM asked
                          • cb007cb
                            • Jan 2014
                            • 51
                            • usa
                            Now getting 6 blinks after second test which is either su sd or sc board have not isolated boards to do test yet! The voltage at sc2 starts at about 10 and fades lower very slowly.No idea where sos6 is other than it leads to the big flat lead that goes to a board.Why does the tv turn on as soon as its plugged in? Here relay click 10 second delay green lights go on fan goes on and off 2 seconds then the green lights slowly fade!
                            • cb007cb
                              • Jan 2014
                              • 51
                              • usa
                              Ran the test for su sd sc board it says after isolation tv on its the su or sd board.Tv not on replace sc board.Well it fires up as before green lights on NO FANS THIS TIME then turns off and green light fades.So i am none the wiser after running the panasonic tests!!!!
                              Why does it fire as soon as plugged in why the on off switch not working?If a quick fire up counts as power then its sc board if not im still in the dark!!Even when you go by the book it can still be wrong!!!!
                              • cb007cb
                                • Jan 2014
                                • 51
                                • usa
                                tv on its the su or sd board not sc as i said above!No power is sc board.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Ok, I'm getting confused and a deep breath I guess.
                                  I'm not sure if you're power switch is soft start on or a latched switch but If the last command was to turn on TV then when power is restored it starts straight away. if it was in standby it would remain in standby.
                                  For my 2010 which has a latched switch this is what it does. I have induced a SOS7 with Sc2 removed.
                                  Master switch on, powerup via remote, bootup, fail, SOS7. Unable to control with remote. Master switch to off, LED out, master on, TV automatically starts, fail, SOS7, switch still on, remove cord, plug cord back in auto boot up, fail SOS7.
                                  Now, with functional TV, turn on, completes, place in standby, turn master switch off, LED out, turn on, Standby, turn off, remove cord, plug cord back in, switch on and still standby.
                                  We'll try this and see if it clarifies anything. The book suggests disconnect, 3 white ribbons A31,A32,A33 and TV should turn on and stay on.
                                  I myself like, those three plus SC2,SS11 and P35 removed. If the PSU and A boards have no issues it should just turn on with the panel off.
                                  TPSOS6 highlighted near Sc20, which is dead easy to get to and a dedicated test pad, since Tom has mentioned this and might be useful. I have not encountered a SOS6 misdetection on the A board but have read of it and Tom may have some additional background info on it .
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Keep forgetting to mention this but avoid reconnecting any power cable immediately after having the PSU on and then shutdown for risk of spiking boards especially the C buffers with P35 as can destroy the ICs on the ribbons. Voltage can be high for several minutes.
                                    • cb007cb
                                      • Jan 2014
                                      • 51
                                      • usa
                                      Thanks for the diagram sos6 TW just checked it power on 6 second delay goes to 4.75 volts for about 2 seconds then goes to zero does this give any clue? Let me know so i can do your tests with 31 32 33 ect later...............thanks...CHRIS.
                                        If it is zero when you get 6 blinks I don't think it's at fault.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • 0xx
                                          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                          by 0xx
                                          Hi folks,
                                          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                          I assumed that Windows Update was interrupted due to closing...
                                          09-14-2025, 03:46 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
