PANASONIC Th-p50g10 6 red blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: PANASONIC Th-p50g10 6 red blinks
    Just another thought, but if you're willing to have a go at that chip replacement, why not try heating up pin 5 and carefully lift that leg to isolate and disable the SOS6 to see what happens.
    • cb007cb
      • Jan 2014
      • 51
      • usa
      #42
      Them chips too small for me to solder but i like the idea of isolating pin5 think i will give that a go have the board out now anyway will let you know later.THANKS.
      • tw2005
        • Oct 2011
        • 6458
        Reckon you could take a nice clear closeup of the IC? I'm curious to see. Yes it can be a challenge, I have to use magnifiers.
        These boards seem hard to find, only saw broken ones. So you may need that board as a core for repair so be neat.
        • cb007cb
          • Jan 2014
          • 51
          • usa
          #44
          Thanks TW heres the picture the 5th leg is on the left 5 down from the top right?It says 1 on the board at the top left!!https://www.badcaps.net/forum/images...nsertimage.gif
          • cb007cb
            • Jan 2014
            • 51
            • usa
            #45
            picture.....
            • cb007cb
              • Jan 2014
              • 51
              • usa
              #46
              Did it TW but its the same also now when i take off ribbons it cuts out before the fans and boards would keep going?Any ideas?
              • tw2005
                • Oct 2011
                • 6458
                No, probably time to stop messing with it. Obviously more complex than I hoped.
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • 0xx
                  2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                  by 0xx
                  Hi folks,
                  My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                  What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                  I assumed that Windows Update was interrupted due to closing...
                  09-14-2025, 03:46 PM
                • Biruslapio
                  Panasonic P58V11B 8 and 12 blinks error "fix"
                  by Biruslapio
                  Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                  Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                  04-13-2021, 07:13 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • CrewmanRedShirt
                  Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                  by CrewmanRedShirt
                  Hello all,
                  As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                  07-13-2024, 11:02 AM
