Need bios for la-b091
  • Francisco.s
    • 686
    • Spain
    Need bios for Lenovo B50 mobo la-b091p.
    I've already tried some dumps, but none of them seems to be the correct one.
    (BIOS LENOVO A8CN33WW(V2.01))
    I've also reprogrammed the Nuvoton embedded controller NPCE288N.
    Problem is that doesn't post correctly. has no video on lcd nor external connector.
    thanks.
    This is the bios backup:
    Forgot to mention that it behaves the same with or without ddr3 memory.
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: Need bios for la-b091
    A8CN54WW clean dump bios
    • Francisco.s
      • 686
      • Spain
      Hi, thanks for your dump.
      It doesn't works for me.
      I don't know if it is a compatible dump. I can not find the original one.(A8CN33WW(V2.01))
      I've also tried other dumps like $A8CN53WW(V3.06) and not work either.
      When power-on, input current raises from 13 mA. to 220 mA. ant past 5 seconds input current goes back to 13mA.
      CPU voltage are OK, but it stays cold.
      Any comments will be appreciated.
      • Elsid79
        • Aug 2015
        • 47
        • Ukraine
        Do you program two flash drives, main bios flash and EC bios ? try it
        Lenovo_b50-80-80lt
        bios a8cn38ww(v2.03)
        ec a8ec38ww(v2.03)
        • Francisco.s
          • 686
          • Spain
          Lenovo_b50-80-80lt
          ec a8ec38ww(v2.03)
          Hi, there's only one bios inside the rar file, and as I commented at the begining, I've also reprogrammed the Nuvoton embedded controller NPCE288N with a file from another website.
          Thanks.
          Pd: this is the file programmed to kbc:
          • Elsid79
            • Aug 2015
            • 47
            • Ukraine
            try it dump KBC
            lenovo b50-80 ec LA-B091P
            nuvoton 288
            • Francisco.s
              • 686
              • Spain
              There is no difference with this nuvoton 288 file, it behaves the same.
              It seems like main bios is corrupted or cpu/memory problem.
              Main bios receives pulses at pin 1, but seems to hang in the process. (only a few pulses, I think not enough to complete POST)
              Perhaps with the correct dump, it works.
              • yalcinfakir@gmail.com
                • Dec 2017
                • 6
                • TR
                Elsid79 Tesekkürler.Sizin verdiginiz bios çalıştı.A8CN54WW clean dump bios working teşekkürler...
                • ktmduke
                  • May 2013
                  • 1
                  • Turkey
                  Elsid79 thanks boss. dump is working.
                  • MIDOX
                    • Jul 2018
                    • 32
                    • ALGERIA
                    Need bios for Lenovo B50-80EW
                    i5 cpu
                    • comfe
                      • May 2016
                      • 6
                      • Turkey
                      working
                      ty so much
                      • beal
                        • Jul 2017
                        • 117
                        thanks
                        • Access3
                          • Feb 2017
                          • 3
                          • czech
                          hi,please help dump bios,ec lenovo B50-80 model name 80EW mainboard LA-B092P rev3.0 date 2014-12-22 cpu i3-5005u
                          • Access3
                            • Feb 2017
                            • 3
                            • czech
                            Picture mainboard
                            • reza93
                              • Oct 2019
                              • 11
                              • Iran
                              thanks
                              • stanker19
                                • Jun 2017
                                • 14
                                • Việt Nam
                                bios good .Thanks
                                • Atiq
                                  • Dec 2017
                                  • 78
                                  • India
                                  Hello Friends,
                                  I have Lenovo B50-70 (20384) no display
                                  la-b091p rev 1.0
                                  All help will be very appreciated.
                                  Thank you very much
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
