HP 15 bios dump need!!! (LA-A994P)
  • bios77
    • Feb 2015
    • 4
    • yalova
    Hp 250 g3 (la-a994p ) bios please
  • maestro_lpc
    • Mar 2015
    • 14
    • Georgia
    Re: Hp 250 g3 bios dump
    What BID you want? There are 4 bios dump 8mb.
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      Hi guys good day.. please help me.. i need bios dump for my hp laptop.
      here is the board model: LA-A994P REV: 2.0
      thanks guys
      • dspok
        • Jan 2014
        • 553
        • Nepal
        Re: HP 15 bios dump need!!! (LA-A994P)
        one of the attached bios will work.
        save your old bios & try.
        • rachid34000
          • Jan 2015
          • 2
          • algeria
          think you
          • minhaj
            • Jul 2015
            • 13
            • india
            thanks you
            • jatoi
              • Jan 2015
              • 83
              • pakistan
              thanks
              • makina1982
                • Sep 2014
                • 4
                • Chile
                plase i need dump zs040 la-a995p
                thank a lot!
                • angel-boy
                  • 550
                  • Romania
                  try this one....
                  • Lex-
                    • May 2011
                    • 18
                    Please help, I need EC (KB9012) dump ZSO40 LA-A995P or a way to extract it from the hp BIOS update. Thanks.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      no EC update from web update
                      this laptop has 4 versions of the boards, here is 4 bioses
                      Im Back... sort of...
                      • Lex-
                        • May 2011
                        • 18
                        Thank you ala_borbe, my board version is 0220F, flashed it with the file provided by you, but still no image on display, I think that maybe EC firmware corrupted because the board uses KB9012 and becomes corrupted frequently, I have the programmer for EC, only need the correct dump to flash it, any advice please ?
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          well try this
                          found on some site, not my work
                          it also may not be bios or ec problem, many other things may cause similar symptoms
                          bios f18 + ec
                          • ridamouh159
                            • Nov 2014
                            • 365
                            • maroc
                            This is for hp250 g3 core i3
                            • makina1982
                              • Sep 2014
                              • 4
                              • Chile
                              thanks angel-boy but dont work :-(
                              • alas3376
                                • Nov 2011
                                • 382
                                • BENIN
                                thanks
                                • MetalSerj
                                  • Dec 2015
                                  • 3
                                  • Moldova Republic of
                                  thanks friend!!!
                                  • ibrahim_yas
                                    Banned
                                    • Nov 2015
                                    • 20
                                    • 86159159666
                                    thanks u very much admin
                                    • ibrahim_yas
                                      Banned
                                      • Nov 2015
                                      • 20
                                      • 86159159666
                                      again thanks you..
                                      • sandaruwan
                                        • Dec 2014
                                        • 19
                                        • Sri Lanka
                                        thanks
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
