Sony KDL-46S4100
  • R_J
    • Jun 2012
    • 9518
    Sony KDL-46S4100
    The problem is No picture, or sometimes picture with lines, sound ok, Back light O.K.
    I removed the metal from around the lcd panel to gain access.
    I suspected, tab bond, and it most likley is, except its NOT an issue with the tab bond to the PC board, it looks like an issue with the bond to the panel itself. I was able to lift the lcd panel up slightly and the picture was perfect, I then pressed lightly in the area circled and the picture would give lines etc. and sometimes would go out completely. When it went out completely the set would need to be turned off and back on to get the picture back.
    With the panel lifted up about 1/4 inch and perfect picture I could press around the tab to pc bond and it had no effect, but touch in the area circled and lines all over that half of the screen.
    So I think when people put pressure on the printed circuit side of the cable it flexes the cable at the panel giving a good connection for a while.
    I will do some more checking to try and isolate it more. And there will be no video.
  • R_J
    • Jun 2012
    • 9518
    Re: Sony KDL-46S4100
    I was able to place a small pad where the flex cable meets the panel, so far that seems to have kept the connection intact, This was the last tab on the upper right (looking from the front) only time will tell.
    • noisykid
      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
      by noisykid
      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
      12-30-2024, 07:15 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • CyberPhoenix
      Issue with picture quality of Sony bravia TV
      by CyberPhoenix
      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
      01-22-2024, 02:08 AM
    • Chrissygizmo
      Sony KD-55XG9505 lines on screen problem
      by Chrissygizmo
      Hello again everyone,
      This is my latest mission, to try getting this Sony tv back to normal working order…
      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
      02-19-2025, 11:31 AM
    • tree5656
      diagnosing sony XBR-75X900H. NO PICTURE
      by tree5656
      This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
      11-09-2023, 04:55 PM
