Insignia NS-LCD32_7D21 power supply
    Got this one in today (made in year 2007), the unit has standby voltage, but when power ON is activated I can hear small buzzing/sizzling sound from the power supply. The heatsink for the MOSFET PFC, Diode gets hot fast. The 12v has about 4v, the 24v has about 6V output.
    Check the DC voltage on the main cap (150uF 450VDC) in standby, it has about 120VDC, put meter in AC mode to read AC voltage on the cap, it shows 80VAC!.
    Remove the main cap and test the value, it shows about 30uF, ESR is off the scale, more than 10 Ohms.
    Put in new main caps, TV now works good, replace the rest of the caps, will be burning in for about 1 week.
  • capkid
    • Oct 2010
    • 1339
    Re: Insignia NS-LCD32_7D21 power supply
    I'd never heard of Jianghai caps. It appears to be a Chinese company.
    LG Plasma Mal-Discharge Correction Service
    • R_J
      • Jun 2012
      • 9540
      The top of that cap (picture 6) looks a little pointy, I'll bet if you take the plastic off the top it will have poped.
        Nice fix! Lucky it did not blow the PFC, that usually happens with bad output cap.
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
