HARMAN KARDON AVR235 repair
  • PowellSkier
    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
    by PowellSkier
    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
    06-17-2024, 11:43 AM
  • funky2x
    Harman kardon onyx studio 7 Smd code
    by funky2x
    Cant find what smd code Y0DVA.
    sitting in Harman kardon onyx studio 7. Appreciate any help.
    05-29-2025, 03:44 PM
  • PowellSkier
    Cement resistor swap in Harman Kardon AVR
    by PowellSkier
    Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
    06-04-2024, 06:41 PM
  • falafinasul
    Harman Kardon AVR 3700 Fonte queimada
    by falafinasul
    Harman Kardon AVR 3700 burned, it does not turn on and I have already changed the fuse and when turned on it burns again. It must be shorted.
    I made a new Diagnostic and verified that the input source is shorted.
    Someone help
    02-24-2023, 05:51 PM
  • BlackScreen_22
    Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
    by BlackScreen_22
    Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
    Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
    I had no problems connecting mosfets and capacitors,...
    08-27-2024, 12:46 PM
