Asus G750JW EC (IT8585E) replaced
  • JLCurve
    • Feb 2017
    • 32
    I'm a bit lost here...
    I have a G750JW gaming laptop that had shorted EC chip (IT8585E). I have replaced the chip. I have a Vertyanov programmer but no pin reference for this model. Anyways I understand that is is self programmed by the PCH on these models.
    When I apply power, the power light turns ON instantly and no fan for about 45 seconds. (About the time it takes to program the EC chip). Then, FANS come full-on, except the CPU fan speed oscillated (kind of ON-OFF-ON-OFF..) at 1Hz period.
    The computer does not boot.
    Anybody has seen that?
    Thanks!
    J.
  • khaahk
    • Dec 2013
    • 789
    • Estonia
    Re: Asus G750JW EC (IT8585E) replaced
    The EC should be reprogrammed automatically.
    How did it happen (short)? Was the IT8585E new?
    Reprogram bios.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      did u see this?
      https://www.youtube.com/watch?v=pesgx6cLa9A
      • JLCurve
        • Feb 2017
        • 32
        No idea why the IT8585E had shorted in the first place. I replaced it with a new one. I no longer have the initial short circuit, confirming that (at least) the 8585 was bad.
        I would like to verify if the chip is being programmed but I do not have the pin assignment (KB connector to EC signals) for this motherboard.
        Still looking...
        Thanks,
        J.
        • techman1025
          • Jun 2014
          • 497
          Hi
          Here is the firmware it needs to be reprogrammed i hope you have the right tools. Asus Gamming G750JW-intel 4th Gen
          Motherboard model : G750JW -Rev:2.1
          I/O chipset : ITE8585E ( EC rom )
          Techman1025
          • techman1025
            • Jun 2014
            • 497
            Hi No data sheet this is what i use.
            Techman1025
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              I have boardview for this motherboard, what version you have ?
              • JLCurve
                • Feb 2017
                • 32
                G750JW REV 2.1
                Thanks,
                J
                • chinsoon
                  • Aug 2016
                  • 2
                  • Singapore
                  Have you solve the problem? I am having the same problem. Some said IT8585 does not need to program. EC is in the bios?
                  Originally posted by JLCurve
                  G750JW REV 2.1
                  Thanks,
                  J
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    Originally posted by techman1025
                    Hi
                    Techman1025
                    Thanks bro
                    • Pascal Komlassan
                      • Jan 2017
                      • 809
                      • TOGO
                      Techman1025
                      Good
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        Ec no need programming in this case, only bios but after you have programmed the bios with a dump , reset using ftp.exe -greset or remove bios battery and main battery for 3 or 4 minuts
                        check if the vbios with mmtools it's good for your videocard
                        • jasko_jacker
                          • Oct 2014
                          • 1137
                          • italy
                          this is boardview for all rev
                          • on/off
                            • Oct 2016
                            • 333
                            • Indonesia
                            Thank you very much.
                            • Dygame
                              • Mar 2019
                              • 4
                              • Cote d'Ivoire
                              HELLO.
                              Please someone can help me about ASUS ROG G750jw motherboard?
                              there is one part with 6 pins under the power button board.
                              It is on the mainboard. it is burnt, so I cannot see the part number to change it.
                              help me please.
                              DH-A1LC BGA Rework Station.
                              • Dygame
                                • Mar 2019
                                • 4
                                • Cote d'Ivoire
                                I had same problem, but it was another part that shorted EC (IT8585E), it is under power board, but I cannot get part number.
                                excuse me my english.
                                • myth77
                                  • Feb 2017
                                  • 380
                                  • Croatia
                                  Originally posted by Dygame
                                  HELLO.
                                  help me please.
                                  • Dygame
                                    • Mar 2019
                                    • 4
                                    • Cote d'Ivoire
                                    Oh. Thanks very mutch.
                                    Best regards
                                    • VogonJelc
                                      • Nov 2018
                                      • 7
                                      • Montenegro
                                      jasko is this fritzing file format?
                                      • reyessuper
                                        • May 2015
                                        • 2
                                        • Spain
                                        X550JX VERTYNOV:
                                        X550JX KB_pins=24 PD0=23 PD1=14 PD2=9 PD3=17 PD4=8 PD5=10 PD6=6 PD7=24 BUSY=20 STB=12 AFD=22 INIT=15 SLIN=13 KSI4=16 KSI5=18
