Samsung ue324h5000w no backlight
  • LE GRAND
    • Jul 2014
    • 34
    • TUNISIA
    Re: Samsung ue324h5000w no backlight
    after changing 2S110 now 318v in main cap
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      How did you verify the 4 led strips?
      • LE GRAND
        • Jul 2014
        • 34
        • TUNISIA
        OK WITH Lab Mains Adapter BT305
        IN EACH STRIP I give 30v 0.30 amp
        • LE GRAND
          • Jul 2014
          • 34
          • TUNISIA
          Any idea ,???????????????????
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            So the 4 strips tested at 30V, 300mA per strip would appear to show the leds are fine. The board says 140V @ 260mA. With 4 strips in series would be about right.
            without the schematic for the power supply it is difficult know what else to check.
            However the Backlight On and P_Dim should not be 0V and you already said that with the main board disconnected and connecting A5 to BL_ON using a 1K resistor and A5 to P_Dim again using a second 1K resistor did not bring the leds on.
            What voltage do you have on each side of D9101
              What DCV do you have between GND and the Cathode (band) of DM852? That Voltage (low Voltage) is the feeding Voltage that feed the Boost converter circuit to produce the 140VDC for the LED.
              I expect to see that feeding Voltage (low Voltage) to be present at all time.
              • LE GRAND
                • Jul 2014
                • 34
                • TUNISIA
                #27
                voltage on each side of D9101 -----------0.00V
                voltage oN DM852------------60V
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  What's the IC part number as printed on it.
                  • LE GRAND
                    • Jul 2014
                    • 34
                    • TUNISIA
                    #29
                    may be SLK2012M IM NOT SURE I CANT READ
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      #30
                      Cannot find anything on that number but could find SLC2012M listed as a power supply drive control IC
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #31
                        The IC looks very much like a FAN7340 in layout. Can you measure very carefully what DC voltages you have on the pins 1 - 16 with the black meter lead connected to pin 3.
                        http://pdf1.alldatasheet.com/datashe...D/FAN7340.html
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          #32
                          What's the part number and what voltages do you have on the 3 pins?
                          • LE GRAND
                            • Jul 2014
                            • 34
                            • TUNISIA
                            #33
                            Gnd is 4 leg
                            1. 12 .8 v
                            2. 105 mv
                            3. 105 mv
                            4. Gnd
                            5. 4 .8 v
                            6. 120 mv
                            7. 86 mv
                            8. 105 mv
                            9. ~4 v
                            10. 3.5 v
                            11. Nc
                            12. 100 mv
                            13. 105 mv
                            14. 93 mv
                            15. 0.77 v
                            16. 87 mv
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              #34
                              Good find.
                              • LE GRAND
                                • Jul 2014
                                • 34
                                • TUNISIA
                                #35
                                MDD5N40 N-Channel MOSFET
                                D 124V
                                G 0V
                                S 0V
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #36
                                  Here's a Samsung model using the same LED driver giving voltages.
                                  So you have your 120V for driving the leds. What voltage on pin 11? It's pin 10 that's NC.
                                  Looking like the led driver is faulty since there does not appear to be any drive voltage to the mosfet.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #37
                                    Just taken another look at the information you provided.
                                    If the drain of the mosfet is at 124V then that should pass through a diode and arrive at CNL802.
                                    Can you confirm the 124V is on pins "Top1-"
                                    • LE GRAND
                                      • Jul 2014
                                      • 34
                                      • TUNISIA
                                      #38
                                      BIG THANKS TO dick_barton
                                      After changing SLC2012M the backlight is coming
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        #39
                                        Thank God. I though we would never get there.
                                        • LE GRAND
                                          • Jul 2014
                                          • 34
                                          • TUNISIA
                                          #40
                                          hhh me too
                                            09-07-2024, 05:50 AM
                                          • sansanpartida
                                            Samsung QE82Q70RAT no backlight
                                            by sansanpartida
                                            Hi everyone!
                                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                            My issue: No backlight.
                                            Model: QE82Q70RAT
                                            Type No: QE82Q70RAT
                                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                            So hopefully, I can fix this cheaper.
                                            05-22-2024, 06:56 AM
                                          • howardc64
                                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                            by howardc64
                                            TV was fixed just after removing Samsung's rear snap cover.
                                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                            Maybe PSU->backlight connector didn't have a good contact?...
                                            07-23-2025, 12:34 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
