E153FPf problem
  • vonviener
    • Jan 2010
    • 7
    E153FPf problem
    Hello everyone. I have a dell E153FPf monitor that decided to stop working. I did a search and didn't find much info on my monitor that has the all in one board like the link below.
    click here for picture
    The monitor turns on and has a solid green light but the backlights don't turn on. The backlights never flicker on at all. The capacitors looked good but I swapped the large ones out anyway and I re-soldered every joint on the board. I am not sure if it is worth replacing the little 47uf/16v caps as well. Nothing changed with the new caps and re-solder job. The main fuse (T2A/250V) looks to be good as well. This is where my limited abilities end and I look to consult others. I don't see anything obviously damaged so I need so help on where to start checking things out.
    I included two pictures. The back of the board has a little bit of rosin that needs to be cleaned up but no burns, dark areas, or cracked joints. The top looked normal to me but maybe someone will catch something.
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: E153FPf problem
    Thanks.
    It's a little hard to tell anything from those pictures. Try this: https://www.badcaps.net/forum/showthread.php?t=1868 There may be a fuse between the 12V supply and the inverter.
    PlainBill
    • seanc
      • Nov 2008
      • 1319
      Re: E153FPf problem
      I had this problem on an E152FPb, one day the backlights just didn't come on, but the power button was green.
      Re-soldered all of the transformers and replaced the blown Pico fuse with another fuse (a radial type I think) of the correct rating and it's been working fine, nice and bright for the last couple of times I've used it.
      Took me about a year to get round to finding another fuse to rob out of something
      Due to the fuse being a different type, I had to solder it onto some wires, insulate it all and then solder to the board.
      • vonviener
        • Jan 2010
        • 7
        Re: E153FPf problem
        Hopefully better pictures....
        • PlainBill
          • Feb 2009
          • 7034
          Re: E153FPf problem
          Much better, thanks. This design makes troubleshooting a lot more difficult, but here's a try. First of all, you didn't explicitly state that the power LED responds to the power button.If it does, continue.
          Next, hook it up to a computer and verify that you can see the desktop (or other computer generated display) when a bright light is shined on the screen. If you can, you definitely have a backlight problem. Again, continue.
          These tests must be done with the power ON, and preferably the monitor hooked to a working computer. Please be very careful, while it is unlikely you would get a fatal shock, it could jangle your nerves.
          On the bottom of the board I have labeled two points 1 and 2. These should be the On / Off and brightness signals from the the display controller on the other end of the board. Try to measure the voltage on these points relative to ground (the mounting hole above and to the left of the points). Try this with the power LED on, and again with it off. Also, there is a heavier trace also coming from the display controller. What is the voltage on that point? And rounding out the bottom of the board, there is a very heavy trace just to the left of PS, 1, and 2. That appears to be the supply for the inverter drivers. What is the voltage there?
          Now for the top of the board. Just to the right of L804 is a point I have labeled IP and marked with a red circle. What is the voltage there? And lastly, I have marked U1 with IC in red. That is the Inverter Controller. What is the part number?
          PlainBill
          • vonviener
            • Jan 2010
            • 7
            Re: E153FPf problem
            PlainBill
            Sorry, had a bunch of stuff come up.
            1. Power LED responds to power button. Works like normal.
            2. When hooked up to a computer the image is displayed on screen like normal but no back light.
            3. I am not sure if I am doing it right but I received no readings using my multimeter on the spots you highlighted. Front or back. I put the ground on the empty screw hole and the positive in the little hole. Nothing...... Tried ac and dc with monitor on and off. Zip. Like I said though, I am probably doing something wrong. I will try again tomorrow just to be sure.
            4. ic is:
            0Z9RRAC <- or G not sure
            0452A1
            42114912
            Thanks.
            • PlainBill
              • Feb 2009
              • 7034
              Re: E153FPf problem
              4. ic is:
              0452A1
              42114912
              Thanks.
              1 and 2 are good news. You have a backlight problem.
              We will have to investigate the problems measuring a voltage. It would be nice if there was no voltage to measure; power supply issues are easier to troubleshoot than inverter issues.
              The inverter controller appears to be OZ9RRAG, but other than a notice of patent infringement, I have had little luck finding information on it.
              PlainBill
              • ecking767
                • Oct 2009
                • 492
                Re: E153FPf problem
                The OZ9RRAG and the OZ9930 is the same chip. I have seen these chips on Dell E177FP and swap the two to confirm that they are indeed the same chip. So I confirm that the OZ9RRAG and the OZ9930 work when I swap either chip from the inverter circuit. I also made measurement to confirm and noted pin out on both during operation. But there is very little data on the OZ9930 too. But I have a pin out of the OZ9930 I will post later in the evening
                Hope this help
                ecking767
                • vonviener
                  • Jan 2010
                  • 7
                  Re: E153FPf problem
                  Tried it again and got results. I had to hold the tips just right to get a reading.
                  1 = 3.30v dc on and 0v dc off
                  2 = 3.30v dc on and 3.30v dc off
                  PS = 5.02v dc on and 5.1v dc off
                  Thick trace = 12.24v dc on and 12.24v dc off
                  IP = 12.24v dc on and 12.24 dc off
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: E153FPf problem
                    Hope this help
                    ecking767
                    Thanks for the information. I'm looking forward to the pinout.
                    PlainBill
                    • vonviener
                      • Jan 2010
                      • 7
                      Re: E153FPf problem
                      IC chip problem perhaps???
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: E153FPf problem
                        Maybe, but I'd bet on something mundane, like a bad solder joint, broken wire, or user error (Just threw that last in to see if you are paying attention).
                        PlainBill
                        • vonviener
                          • Jan 2010
                          • 7
                          Re: E153FPf problem
                          PlainBill
                          LOL.
                          I didn't have much luck tracking down a replacement ic chip. Which might be the problem (shot in the dark) or one of the problems (too depressing to think about).
                          • ecking767
                            • Oct 2009
                            • 492
                            Re: E153FPf problem
                            sorry for the late post. here what I have on the oz9930 pin out
                            Hope this help
                            ecking767
                            • vonviener
                              • Jan 2010
                              • 7
                              Re: E153FPf problem
                              Thanks!
                              Hope this help
                              ecking767
                              • abdo
                                • Oct 2010
                                • 6
                                Re: E153FPf problem
                                bonjour
                                j ai problemrectroeclaurage au moniteur dell e152fpb d'ou vient la panne merci
                                • abdo
                                  • Oct 2010
                                  • 6
                                  Re: E153FPf problem
                                  [QUOTE = abdo; 130158] bonjour
                                  j ai probleme retro-eclairage au moniteur dell e152fpb d'ou Vient La Panne merci [/ QUOTE]
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Re: E153FPf problem
                                    Originally posted by abdo
                                    bonjour
                                    Quel est le problème?
                                    PlainBill
                                    • abdo
                                      • Oct 2010
                                      • 6
                                      Re: E153FPf problem
                                      salut
                                      avez vous une idèe sur cette panne merci, très inportant
                                      retro-eclairage mème panne que celle qu'avait mr maluko75,vos conseils merci pour la rèparer merci
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Re: E153FPf problem
                                        salut
                                        You must apply the same repairs we suggested to Maluko75. I have attached a corrected picture.
                                        RED circles 2SC5706 or 2SC5707. Test; if shorted replace with 2SC5707.
                                        Blue circles FU9024N. Test, if shorted replace with FU9024N.
                                        Green circle 3 Amp Picofuse. Test, if open replace with 3A, 125V picofuse.
                                        Yellow circles - resolder all pins on the transformers. This is very important.
                                        A complete kit of parts is available here.
                                        Bonjour,
                                        Vous devez appliquer les mêmes réparations que nous a proposé de Maluko75. J'ai joint une image corrigée.
                                        Les cercles rouges ou 2SC5706 2SC5707. Test: si court remplacer par 2SC5707.
                                        Blue cercles FU9024N. Test, si court remplacer par FU9024N.
                                        Cercle vert 3 Amp Picofuse. Test, si elle est ouverte remplacer par 3A, 125V picofuse.
                                        cercles Jaunes - ressouder toutes les broches sur les transformateurs. Ceci est très important.
                                        Un kit complet de pièces est.
                                        N'est-ce pas Google Translate merveilleux? http://translate.google.com
                                        PlainBill
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • Askic
                                          Problem with monitor DS-D5022QE-B
                                          by Askic
                                          Hello to all,
                                          I have a problem with monitor that is delivered together with CCTV system.
                                          The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                                          I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                                          05-31-2023, 03:14 AM
                                        • CptChronic
                                          Samsung LU32J590UQUXEN Monitor display problem
                                          by CptChronic
                                          I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                                          Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                                          But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                                          04-24-2023, 04:33 PM
                                        • tmhobadcap
                                          LG 24MP56HQ-P Monitor Backlight problem?
                                          by tmhobadcap
                                          I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                                          Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                                          I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                                          10-13-2021, 01:52 PM
                                        • tmhobadcap
                                          by tmhobadcap
                                          10-12-2021, 01:43 PM
