Dell 2407WFPb Monitor - Bad Cap
Re: Dell 2407WFPb Monitor - Bad Cap
Put your meter in diode mode and check to see if it is still tested out like Diode.
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
You can try this link, post #8
https://www.badcaps.net/forum/showth...WFPb+schematicComment
Success reviving Benq FP241W
Thanks to the posts in this forum, I was able to fix my Benq FP241W that wasn't powering on and saved a few hundred dollars on a replacement. The Benq FP241W uses the same power supply board as the Dell 2407 and I noticed brown leakage at the positive terminal of the 120uF 450V capacitor (C605) and the ceramic coating on R670 was flaked off. I replaced the components listed by elvena, micdis and others. I didn't test the components to see what had actually failed - I just replaced everything listed below.
Component ID / Replacement Part / Digikey Part Number
C605 / Rubycon 450QXW120MEFC18X31.5 / 1189-1377-ND
Q651 / STMICROELECTRONICS - STP10NK60ZFP / 497-5892-5-ND
IC651 / STMICROELECTRONICS L6561D013TR / 497-4582-1-ND
R669 / Panasonic ERA-8AEB1021V / P1.02KBCCT-ND
ZD601 / Vishay TZMC15-GS08 / TZMC15-GS08CT-ND
IC601 / ON Semiconductor NCP1200D100R2G / NCP1200D100R2GOSCT-ND
R670 / Yageo PNP300JR-73-0R22 / 0.22AECT-ND
F601 / LittleFuse 0234004.MXP / F2692-ND + F1504-ND fuse holder
C622 / Nichicon UPS2A010MDD1TD / 493-5378-1-ND
Q654 / Fairchild Semiconductor MMBT3906 / MMBT3906FSCT-ND
D655 / Diodes Inc. 1N4148W-7-F / 1N4148W-FDICT-ND
As a precaution, I replaced these other caps on the power supply board:
C711-C715 / Panasonic EEU-FM1V471 / P12415-ND
and these three caps on the CCFL driver board:
? / Nichicon UHE1V221MPD6 / 493-1579-ND
I'd never de-soldered/soldered surface mount components before, so I practiced for a while using a dead board. I found I had to be careful when de-soldering ICs and SMT transistors to avoid tearing off the contact pads.Comment
I have a 7-8 yrs. old Dell 2405fpw monitor and also had problem with the power supply board. So far I changed the following components, but when put it back and tried to switch it on, nothing happens:
C605 / 450TXW100MEFC18X35 CAPACITOR, RADIAL, (450V, 100UF, since I couldn't get a 120 uF at the moment)
Q651 / STP10NK60ZFP MOSFET, N, TO-220FP
IC651 / L6561D PFC 90UA START + DISABLE, SMD, 6561
R670 / PNP1WVJT-52-0R22 RESISTOR, 1W, 5%, 0R22
F601 / 0001.2510 FUSE, ANTISURGE, CERAMIC, 4A
C622 / EEUFC2A1R0 CAPACITOR, RADIAL, 100V, 1UF
The fuse kept intact, but no indicates for any life of any sort, what could I else do?Comment
@lipeng, please re-post in 2405 thread or make a new one.
Is this the same board you are working on?
Just a quick update: After have exchanged all components listed in #448 of this thread, the monitor powerd up! I'm writting this update with the newly repaied monitor. Totally amazing
Ps. did change all caps on the power supply board, but not on the CCFL driver board.Comment
Hello to all community,
I also have a 2405 with a failed C605 and all the company of MOSFET and IC that it brought down. In this thread it was mentioned only ZD601 (15V). Even if the remaining Zeners should not be affected by the cap failure, I measured ZD602 and ZD603. Both are 24V, if anybody wanted to know.
CheersComment
plzz tell the number that blcak little chip i cant seePut your meter in diode mode and check to see if it is still tested out like Diode.
http://s807.photobucket.com/user/bud...?sort=3&page=1Comment
What is the IC designator, IC651?Never stop learning
Thanks to this board I have managed to repair my 2405. Many thanks to the contributors. I had the usual initial failures:
R670 (blown - replaced by cheap metal film 2W off ebay)
C605 (blown - replacement sourced from ebay again)
IC651 L6561D (destroyed - replaced over ebay)
Q651 SK3502 (shorted pins on testing - replaced via ebay)
Oddly the fuse was still intact but the monitor did not power on.
Then replaced:
IC601 NCP1200D (from RS couldn't wait!)
ZD601 15V 0.5W zener from local shop
Fired up perfect!Comment
Has anyone got this mod to work on the 2405? I tried this mod with a 19V 4A power supply and still no power???Tyan, the speaker socket/power mod is a simple three-step process:
1) In the photo attached below I have marked both ends of L702, which is to be removed from the PCB, with magenta crosses. De-solder or just cut both ends of this inductor (a bit of wire that passes through a ferrite bead on the component side). This isolates the power socket from it's normal supply circuit.
2) The short blue line shows where to solder a bridging wire to permanently ground the switched contact for the socket CN703 - making it seem that the speaker isn't plugged in. A blob of solder across C718 would also do the trick.
3) Run a decent gauge stranded, insulated wire between the points marked with an orange line. To get a good solder joint on the land between C713 and F701 scrape away the lacquer first. The other end of this wire goes down onto the middle pin of socket CN703 which is already quite well exposed for soldering.
That's really all there is to it! The central pin in the speaker socket may be a little smaller than the power-brick plug (2.1mm vs 2.5mm I think) If it doesn't connect very well, it might be necessary to roll a small piece of copper or tin shim to increase the diameter of the centre pin. If that's too fiddly then you can always swap the socket for the correct sized one, or find an adaptor lead. I slipped a slender wire crimp insert over the pin which worked a treat.Comment
Also, does this mod replace the need to use the power on/off button on the 2405? The reason I ask is that I'm beginning to suspect that I am having a power on triggering problem with the power switch.
How can I bypass the power on button switch on the main board itself?Comment
by keepreadHi there!
Someone gave me their old monitor, it's Dell S2715ht.
The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs... -
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by Borse2008Hi everyone,
Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
Channel: General Capacitor Questions & Issues
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... - Loading...
- No more items.
