Hp g62-460st daax1jmb8c0 rev:c shutdown after a second problem
This topic is closed.
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Hi, HP G62-460ST DAAX1JMB8C0 REV:C is power on but shutting down after a second. i flashed EC and MAIN but the problem is same. When i check with the debug card it is shutting down when it checks CPU. I dont have the schema. Any advice is welcome. Thanks
    PS: it has i3 processor which is onboard so its not removable
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3637
    • slovakia
    Re: Hp g62-460st daax1jmb8c0 rev:c shutdown after a second problem
    u have short in power switched rail. check all big coils for resistance to ground
    • ahmetozay
      • Jul 2013
      • 73
      • turkey
      no short in power rail, checked all coils resistant to ground and its ok.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3637
        • slovakia
        than check all small coils
        • ahmetozay
          • Jul 2013
          • 73
          • turkey
          checked all on motherboard no short circuit. when i bend the board it works so there is a crack or cold joint on the board. still working on it
          • bsb1106
            • Jan 2015
            • 19
            • tunisia
            i have the same problem; but i found short in big coil pl27. if same one have the schematic share it please
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              i suspect cold northbridge i would go for a reballing
              • Wani
                • Oct 2021
                • 3
                • India
                Originally posted by sourcebf
                backup and try .......please reply
                I need bios bin of hp g42-458tu board no is daax1jmb8co rev c
                • tahc81
                  • Nov 2019
                  • 42
                  • Slovakia
                  Search the BIOS request section - https://www.badcaps.net/forum/forumdisplay.php?f=15
                  • dellxps15
                    macbook pro 15 late 2013 shutdown problem
                    by dellxps15
                    hi all, got this macbook that come with a 45 watt charger. i told the owner to replace it with a genuine 85 watt to check if the shutdown were caused by bad psu power, but the owner didnt want to spent the money if macbook had some other problem related to the mainboard. after some try, i see that notebook shut down even with battery. i did so a log aout last shutdown error and he got 2 main error code: -104 and -128 with one is related to bad battery and one to general failure. i googled a bit and discovered that many user with 2013-2014 macbook were getting the same shutdown like this one.....
                    02-25-2021, 04:46 AM
                  • Zeonalbasta
                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                    by Zeonalbasta
                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                    09-13-2024, 01:17 PM
                  • NoteX-Bilişim
                    Acer 5742g bios for shutdown problem after 5 minutes
                    by NoteX-Bilişim
                    bios for shutdown problem after 5 minutes / 5 dakika sonra kapanma sorunu için bios...
                    12-28-2022, 07:29 AM
                  • ahmarzo
                    Lenovo nm-b321 v1. 0 shutdown problem
                    by ahmarzo
                    Have lenovo nm-b321 motherboard it shutsdown after 1 min 10 seconds everytime. Have flashed the bios from official site and flashed ec bios also but same problem. Have checked with or without hard disk. What is the problem please help have checked without the keyboard also.
                    10-27-2022, 09:58 AM
                  • Gibon378
                    Problem with stopping audio and video for no reason
                    by Gibon378
                    PC Specs:
                    • CPU: Ryzen 5 1600
                    • GPU: GTX 1080 Palit JetStream
                    • MOBO: ASRock ab350 PRO4
                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                    • PSU: XFX 650W (don't remember what model)
                    • OS SSD: ADATA SP920
                    • OS: Windows 10 21H2
                    Problem description:
                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                    11-19-2022, 09:41 AM
