Razer laptop - won't boot to bootable media - very odd
  • survivalbloke
    • Aug 2021
    • 298
    This is really weird. We got in a Razer laptop "Blade Stealth 13"
    • Late 2019
    • model RZ09-03100EM1
    • product version: 2.04
    • SN:BY2011A79600458
    • BIOS version 1.02
    • EC firmware v 1.01
    • MCU firmware version 1.00.06.00
    It came in because it was in a Windows 11 auto repair/BSoD loop. There were no dump files present on the drive which was odd. I attempted to boot into a Windows bootable USB and after selecting the USB, I would get a Windows logo and progress circle, then the system would halt and I get a BSoD. Each time the stop code is different. I have tried bootable USB drives with Windows 10 in both UEFI and MBR, Windows 11 in both Rufus and media creation tool, ESET bootable live scanner(which halts with a kernel panic, kernel stack corrupt error). I've disabled secure boot, TPM, fast boot, virtulization, you name it. I've enabled legacy and CSM - nothing works. The only live media I can boot to is Memtest86. Since I could boot Memtest, I went ahead and ran it, coming back fine. Are we possibly looking at a bad CPU here?
    video
  • reformatt
    • Feb 2020
    • 1412
    Re: Razer laptop - won't boot to bootable media - very odd
    If the stop code is random, first thing to look at is RAM. So check the pins of each socket and also the RAM itself.
    Also try an older Windows 10 build (like 1803). Another thing is use a SSD with Windows 10 already on it from another system, should at least boot and try to install devices etc. You can then work at which driver causes it to crash when you load each one (like GPU for example).
    If all that fails, then try Ubuntu. If that fails then definite hardware issue.
    • survivalbloke
      • Aug 2021
      • 298
      Thank you for the ideas. The RAM is LP , non serviceable. It BSoD'd using another drive with Windows and when I tried to boot into Ubuntu, I got a kernel panic, so this machine is toast. Thank you for your response - cheers!
      • mon2
        • Dec 2019
        • 14216
        Download RUFUS -> create a bootable FreeDOS USB thumbdrive using the pull-down options.
        Does that boot on your unit?
        • survivalbloke
          • Aug 2021
          • 298
          It does not.
          • mon2
            • Dec 2019
            • 14216
            Are you able to reflash the bios using the USB media?
            • survivalbloke
              • Aug 2021
              • 298
              I don't know how to do that, actually. The only way I know to flash BIOS on a machine which won't boot up, is to use a chip programmer.
              • mon2
                • Dec 2019
                • 14216
                Most current bioses have a menu selection in the bios to upgrade the bios. To do this, you must download the bios from the vendor website and extract the contents onto a USB stick. Then select that option in the bios and it should locate this file on the usb media.
                Just a simple test to confirm if the USB interface is functional and to also confirm that your bios is up to date.
                The vendor does not expect everyone to own an offline programming tool so they allow for in-system updates.
                • privato89
                  Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                  by privato89
                  I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                  Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                  Let's begin:
                  Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                  03-26-2024, 06:37 AM
                • Luke Anders
                  Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                  by Luke Anders
                  Hi everyone,
                  A few details about the laptop itself:
                  Name: Lenovo Legion 5
                  Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                  BIOS Version: GKCN60WW
                  EC Version: GKEC65WW
                  Serial Number: PF39AQ7Z
                  Board Model: NM-D562 Rev 3.0
                  RAM: 16GB Installed, DDR4 (brand new)
                  NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                  I bought this laptop recently from eBay as a faulty device....
                  10-12-2024, 05:13 AM
                • mrfree2ita
                  ThinkPad T14s Gen 1 boot loop (instability)
                  by mrfree2ita
                  Hi all, I'm looking at what seems to be a nice puzzle
                  A ThinkPad T14s Gen 1 that stopped working more or less a month after the warranty expired. I tried to boot both Windows 10 and Debian 12 from a USB stick. In the first case, the system just reboots after showing the Windows logo for a few seconds, while I'm able to see the Linux kernel crashing if I boot the second in failsafe mode.
                  Interestingly, some times (unfortunately it's difficult to replicate) I manage to boot into Debian 12 live. Moreover, the kernel doesn't seem to crash always at the same point during...
                  05-25-2024, 03:43 PM
                • NolesFan
                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                  by NolesFan
                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                  10-24-2024, 06:36 PM
                • Kazuhira
                  I want to create bootable media on a virtual USB flash drive or external SSD.
                  by Kazuhira
                  Hello.
                  I would like to recognize a “virtual USB stick” or “external SSD with USB connection” as a tool that tells me to “connect a USB stick”.
                  Is there a good way to do this ?​
                  10-29-2024, 01:28 AM
