I want to create bootable media on a virtual USB flash drive or external SSD.
  • Kazuhira
    • Mar 2024
    • 8
    • Japan
    Hello.
    I would like to recognize a “virtual USB stick” or “external SSD with USB connection” as a tool that tells me to “connect a USB stick”.
    Is there a good way to do this ?​
    • 31557
    you mean you want the pc bios to boot from it?
    then you need an ISO file structure.
    • Kazuhira
      • Mar 2024
      • 8
      • Japan
      For example, suppose you download “mediacreationtool.exe” from the Microsoft website and create an installation media.
      At this point, many people will probably select a USB flash drive connected to their PC at the “Please select the media to use” stage.
      Usually, bootable media creation tools like “mediacreationtool.exe” only show removable media such as USB flash drives, so you cannot select external SSDs or other non-removable media.
      However, I would like to select here an external SSD or a virtual mounted USB stick.​
        • 31557
        try RUFUS
        https://rufus.ie/en/
        • Kazuhira
          • Mar 2024
          • 8
          • Japan
          Unfortunately, RUFUS did not solve that problem either.
          Like other media creation tools, it seems that only removable media can be selected as targets.
          External SSDs and VHDs mounted as removable media using Imdisk could not be the media creation destination.
          • survivalbloke
            Razer laptop - won't boot to bootable media - very odd
            by survivalbloke
            This is really weird. We got in a Razer laptop "Blade Stealth 13"
            • Late 2019
            • model RZ09-03100EM1
            • product version: 2.04
            • SN:BY2011A79600458
            • BIOS version 1.02
            • EC firmware v 1.01
            • MCU firmware version 1.00.06.00
            It came in because it was in a Windows 11 auto repair/BSoD loop. There were no dump files present on the drive which was odd. I attempted to boot into a Windows bootable USB and after selecting the USB, I would get a Windows logo and progress circle, then the system would halt and I get a BSoD. Each time the stop code is different. I have tried bootable...
            04-11-2023, 05:37 PM
          • ekozeko333
            by ekozeko333
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
          • corrize
            Nikon D800 camera - flash don’t work and capacitor don’t charge
            by corrize
            Hello, I'm stuck in troubleshooting…
            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
            10-01-2022, 10:02 AM
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
          • ArchangelGabriel
            Aorus 17G YD laptop, broken display, could not switch to external monitor
            by ArchangelGabriel
            Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
            11-23-2023, 03:55 AM
