Samsung LE26A457C1D Power problem, It Banged
  • aar5384
    • Jan 2014
    • 82
    • England
    Heres another one of the Tv's ive been having a play with. Its one of the collection from the local tip that one of my friends gives me for a couple of quid who works there.
    The tv wouldnt turn on, I checked the fuse in this one! There was no lights or nothing happening. I looked at the mainboard and couldnt see any bulging or leaky caps by eye and just out of curiosity i thought id try changing the fuse on the power board BN44-00214A, However I didnt have any ceramic ones to hand and so just popped a glass 3 amp one in.
    Plugged it in and bang! Crackle! the fuse exploded shattering it.
    Had another look and the little blue disc cap ( i think ) at CM810 appears to have blown or shorted with a rail J839 and made one of the legs of the cap burn off.
    So, looking for ideas..
    Help
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung LE26A457C1D Power problem, It Banged
    Hope you have plenty time and patience as I think your first major task may be to get that brown glue off. £It looks like the sort that becomes conductive..Try softening it with isopropyl alcohol the just carefully scrape away at it
    When you tire of that - in around 3 minutes perhaps try and find the threads that say how to use a lightbulb to reduce current while testing.
    It is also on the www
    heres 1
    https://www.badcaps.net/forum/showth...t+bulb+current
    • aar5384
      • Jan 2014
      • 82
      • England
      It sounds like its not going to be as easy as i thought.
      The cap that shorted out on the rail, lets say i replace that in a way that it doesnt short out on the rail next to it, fit a new fuse to the board, whats the chances of it going bang straight away and scaring the crap outa me?
      • aar5384
        • Jan 2014
        • 82
        • England
        Well i got a little board so i removed the glue stuff, it just appears the cap shorted its leg out on the bridge wire, so i resoldered its leg back into place and now im just a little on edge wether to pop a fuse into it and turn it on incase it goes bang and sets on fire ?!?
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Have you not got an old type filament bulb 75 or 100w - you just need connect it on the mains positive input and it will save any bangs.
          Reading lamp / desk light/ inspection light
          If the bulb lights bright it means there is probably a short on the set.
          Otherwise stand well back and shield yourself especially eyes.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            I suppose you could do some checks before.
            Test the Bridge rectifier and test the BIG Cap to see if its shorted.
            Make sure its discharged first
            • aar5384
              • Jan 2014
              • 82
              • England
              Ive done a test on the bridge rectifier and across the centre 2 pins i get a reading with positvie on the left and negative on the right of the 2 centre pins , am i right in believing that i should not have any reading at all, in diode mode on multimeter with part out of board
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                you shouldnt get and reading either way on those 2 pins AC AC.
                fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                • aar5384
                  • Jan 2014
                  • 82
                  • England
                  Im getting a reading of 639. Would it cause further damage along the line other than blow the fuse do you think? I did take out the big cap and got a reading out of it to what i cannot remember though it was the other day.
                  Otherwise, i shall order a part and refit and fire it up and stand well back clenching my eyes lol
                    Remove ALL the glue, I can see burnt section on the blue cap which is exposed to high voltage. Also seed dark brown glue on the TO-220 device. The glues are conductive and corrosive.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      If that cap you "mended" is a blue ceramic high voltage cap I would get a new one when you order the bridge. It is unlikely to hold up.
                      • aar5384
                        • Jan 2014
                        • 82
                        • England
                        Ive removed as much glue as i can and made sure all legs are free of the stuff. Im looking for the TO-220 device and struggling to find it, can you give me a hint?
                        For the capacitor i "mended" it was a bit of a bodge when i got bored and i have now removed it, its a 1kv 2.2nf according to the schematics and cpc had something looking very different http://cpc.farnell.com/jsp/search/pr...&Ntt=1kv+2.2nf but i think fleabay has some unless you know a good supplier in the uk?
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          TO-220 - from main input connector diagonally to the right - just above the blue cap.
                          EDIT how about this?
                          http://cpc.farnell.com/murata/debf33...age/dp/CA05022
                          • aar5384
                            • Jan 2014
                            • 82
                            • England
                            Nope now im completely lost lol
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              Oh dear.
                              Did you see my edit
                                The 2.2nf cap is the blue rectangular cap? the one with burnt glue is the blue ceramic high voltage cap to the left of the heat sink on the bottom right of the board.
                                • aar5384
                                  • Jan 2014
                                  • 82
                                  • England
                                  Ohhhh i was looking at that but all i got on that is QB802 and on the sheet it says 80v 4A thats proberbly why i didnt understand. Im not up on component names without a bit of lookin up sorry but thanks
                                  • aar5384
                                    • Jan 2014
                                    • 82
                                    • England
                                    Looks fine that one it was just covered in glue lol The one i thought you were talking of is the lil blue disc cap just underneath the big cap
                                    • aar5384
                                      • Jan 2014
                                      • 82
                                      • England
                                      Yes! I saw this the other day while looking a bit more in depth i just passed on it thinking maybe its different for saying 1000v instead of 1kv when they are both the same thing :/
                                      • aar5384
                                        • Jan 2014
                                        • 82
                                        • England
                                        Okay, new parts have come, new bridge rectifier and little blue cap along with a bunch of new fuses.
                                        Fitted them all in well and gave it a whirl, standing well back expecting another bang pop fizzle, and nothing happened, so i checked for current and theres no power coming in, suspecting blown fuse in plug i changed it and still nothing, checked the fuses and all had blown again. So i checked the soldering and lines for making sure theres nothing shorted out and all is clear and im stuck what i should check next
                                        Any ideas for me?
                                          09-07-2024, 05:50 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
