Samsung LE26A457C1D Power problem, It Banged
Re: Samsung LE26A457C1D Power problem, It Banged
Across the PADS on the board, what do you measure (2000 ohms) across + and -. Note: Bridge out of circuit. You are testing board only.
Hold reading for 10 seconds before recording it to allow it to stabilise.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Am i doing this with the power on or off btw?Comment
off im not sure on the resistor colours maybe someone else will confirm for you.Comment
unlikely colour combination see here
http://www.hobby-hour.com/electronic...calculator.phpPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Show us where you are probing please, do it from the bottom of the board ideally, are you saying you see zero, or the same reading your meter shows when probes are not touching?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
http://www.hobby-hour.com/electronic...calculator.phpComment
That resistor would probably not cause your issue, especially if the fuse isn't blowing with bridge removed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I just did it again , the meter just says 1 when im not using it i did it again and it went to 000 after about 10 secondsComment
So it is holding at 000? You have a short after the bridge rectifier then.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
best guess on the resistor is violet green yellow gold black
750kohms based on 4 ringsPlease upload pictures using attachment function when ask for help on the repair
I begining to think this is a dustbin piece, although the £69 price tag on ebay is annoying meComment
Sounds about right - only purpose of that is to discharge the CX### capacitor next to it - it's a safety thing to avoid a shock from that.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
did you check the two transistors on the top and middle heat sinks?Last edited by vinceroger69; 01-15-2014, 03:43 PM.Comment
Ideally, yes. Then check on 2000 ohms between each pair of legs both forwards and backwards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
