Bios gs557-gs558 NM-C681
  • cacla
    • Apr 2015
    • 444
    Hi there i need bios for this board gs557-gs558 NM-681 its lenovo. I dont have the old dump, eeprom is dead. The bios file is 16m. Thanks
    • 21694
    Re: Bios gs557-gs558 NM-681
    post the serial number please
    • cacla
      • Apr 2015
      • 444
      Here mate sn:PF2AZ85A
        • 21694
        Try this one,its a virgin bios with DMI added from a dump.If you want to change the DMI try LVAR tool. EDIT: Try U1 tool not LVAR
        Ideapad 5-15IIL05 Laptop - Type 81YK
        Lenovo IdeaPad 5 15IIL05/Lenovo XiaoXin-15IIL 2020
        • RotVik
          Learning...
          • Feb 2016
          • 57
          • Mexico
          Hello guys, I got a Lenovo GS557 GS558 NM-C681 Lookin for working BIOS, I got 2 dumps from the 2 ICs, Ill Post em
          Basically I plug it in and go to 75ma straight, I push the power button and stay on 75ma and the led flashes 12 times it drops to 0ma and then 75ma again and 12 led flashes again, I have not found any info on that led code whatsoever and I suspect maybe EC or BIOS, tried the from post #4 but same result
          Any ideas? thanks!
          • RotVik
            Learning...
            • Feb 2016
            • 57
            • Mexico
            forgot to upload the files
            • RotVik
              Learning...
              • Feb 2016
              • 57
              • Mexico
              Actually I am not sure one of the dump is the EC, may be the EC BIOS? It's about 1MB, the other one is about 16MB and most certainly the actual BIOS, I have not been able to find another dump to test it and see if that fixes the issue
              • peste
                • Dec 2016
                • 13451
                • ROMANIA
                try..
                • hani002
                  • Apr 2019
                  • 16
                  • Danemark
                  Lenovo IdeaPad 5 15IIL05 GS557 GS558 NM-C681 bios
                  Hi
                  i Need this bios
                  thanks
                    • 21694
                    Re: Lenovo IdeaPad 5 15IIL05 GS557 GS558 NM-C681 bios
                    Originally posted by hani002
                    Hi
                    i Need this bios
                    thanks
                    Post your bios backup and the laptop serial number or model type
                    • phucsinh
                      • Oct 2022
                      • 8
                      • viet nam
                      Hi, every one
                      I need bios Lenovo GS557 NM-C681
                      Thank advance
                      my old bios
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12281
                        Originally posted by phucsinh
                        Hi, every one
                        Thank advance
                        my old bios
                        Serial number ?
                        • trepachka
                          • Oct 2022
                          • 451
                          Hi, I have Ideapad 5 15iil05. When powering on, the keyboard lights up, the charging light comes on and charges the battery, I can hear the fan spinning. However, keyboard is non-responsive, no video display and no backlight. After a while, the notebook turns off, then repeats the same cycle. I suspect the BIOS is corrupted. Please, help me rebuild the BIOS.
                          Serial# PF2F03RT
                          BIOS chip: Winbond 25Q128JVS0
                          Mobo# GS557 GS558 NM-C681 Rev 1.0
                          Thanks.
                          • peste
                            • Dec 2016
                            • 13451
                            • ROMANIA
                            Serial# PF2F03RT
                            Thanks.
                            try post #4
                            • trepachka
                              • Oct 2022
                              • 451
                              Computer is working now just fine. Thanks.
                              • tony187
                                • Jun 2023
                                • 1
                                • america
                                did you fix the problem
                                i have nm 681 lenovo when i turn it on it flashes 12 times then turns off and back to 12 flashs tried to erase and write bios didnt work does anyone know how i can fix it thanks
                                • appie1206
                                  • Oct 2016
                                  • 116
                                  • netherlands
                                  i have a corrupted bios can somebody please fix it..
                                  Serialnumber IS PF29YZ17
                                  ive added the corrupted bios file
                                  thank you
                                  • appie1206
                                    • Oct 2016
                                    • 116
                                    • netherlands
                                    I tried this but it didnt work... can u maby help me? the file is above with serialnumber.
                                    thanks in advance
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12281
                                      thanks in advance
                                      Check the hardware, you don't have a bios problem.
                                      • appie1206
                                        • Oct 2016
                                        • 116
                                        • netherlands
                                        How do you know.... Was the biosfile ok? I chekked everything.
                                        When i power on the laptops is cycling on off..
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
