Safe to try a Power supply that's been in the Rain?
  • DJ_MIX
    • May 2005
    • 118
    If I let the Powersupply dry for a few days would it be safe to try to see if it works?
    It's a Sparkle PS that was in the trash along with the Compusa PC..
    Either way I will gut the fan if else fails...
    Might be funny But if it's dangerous it will let others know.
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    Re: Safe to try a Power supply that's been in the Rain?
    electronics+water=no problem
    electronics+water+electricity=problems
    if you let it dry out completely it will be fine.
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    • japlytic
      • Oct 2005
      • 2086
      Beware of conductive deposits when it is dry... try washing in methylated spirits, let it dry thoroughly, do an insulation check with a megger, if all OK, it still should be OK.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        If your oven can be set as low as 200F (~95C), you might be able to put it in your oven for a half hour or an hour to be sure it is dry. 250F would be too high. I think Topcat uses quartz heaters and a big box fan to dry motherboards.
        PeteS in CA
        • arneson
          • Sep 2005
          • 1267
          So basting may not be a good idea.
          Jim
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
