Re: Gateway 80486-DX2/50 Revival
ugh...can't read my old cd-r's anymore... sigh. bitrot...
EDIT: Flashrom doesn't appear to have any mention of ISA chipsets, so I'm ruling on the safe side (not compatible).Last edited by TechGeek; 09-29-2022, 06:13 PM.Leave a comment:
Tried with external battery power, no change. The BIOS sees it as an IDE drive and forcibly resets it to auto-detection. Unfortunately, the BIOS also has halfway-implemented CHS translation. Ontrack Disk Manager actually fails to install due to the bugged BIOS, either with "Failed to install because of a severe error condition!" or a warning message saying that "This System's BIOS Does Not Fully Support Translation!"
There are newer BIOSes available, but I haven't found a flash utility that I feel comfortable running against it, and I don't have an (E)EPROM programmer.Leave a comment:
your supposed to install the chip driver first.Leave a comment:
MS-DOS 7 (hangs when loading ASPI drivers with the card installed). Can't determine the chip installed on it. (It's got this label on it that I can't remove. I could try to find the mfg. by looking up the MAC address.)Leave a comment:
That's not making a whole lot of sense in relation to eachother. Did you replace the batt with something/anything that will make it retain memory (bug1)?
Bug2 would be technically negated by bug1, and that sounds like more of an issue with the IO controller. Try a different one? If these are known bugs, probably a BIOS update out there somewhere for it....
I wouldn't waste any time trying to hunt down a sub-528mb HDD; especially one that's actually GOOD.... Just get a 512mb CF card with an IDE adapter....and done.
Nope, it's a pair of bugs in the system BIOS that interact in a bad way.
Bug #1- BIOS reverts hard disk configuration to auto-detection on boot, cold or warm.
Bug #2- BIOS tries to implement CHS translation for >528MB hard disks, but doesn't implement it fully and the end result is spectacular corruption of whatever you write to the disk, not to mention that whatever you read from the disk also ends up getting thoroughly trashed if you wrote it to the disk before transplanting it into the 486 system.
So either I'll need a sub-528MB hard disk (in the works) or an add-in BIOS that completely bypasses the (critically broken) INT13h routines when a >528MB hard disk is installed.
I wouldn't waste any time trying to hunt down a sub-528mb HDD; especially one that's actually GOOD.... Just get a 512mb CF card with an IDE adapter....and done.Leave a comment:
I do, but it's that ISA clone-of-a-clone card that causes DOS to hang up. I'll need an actually decent network card to make that happen.Leave a comment:
The Weitek was not a 487 or a 486, that was something different. It's not a "performance penalty" rather it's simply slower due to the lower clock rate than the higher clocked 486DX2 or 486DX4.Leave a comment:
haha, i like your antique 486 system already, because it has two components made in singapore, the wd hard disk and the creative sound blaster sound card. seems singapore was quite the IT manufacturing factory back during the day, then it all went away to other countries. same boat as u guys in the US but since this is not the vip room, i wont comment further.Leave a comment:
do you have a network card with a socket for an eprom on it??
if you do then i can point you to an eprom that gives you an LBA48 ATA driver extension!!Leave a comment:
If you want to make a bigger drive behave on this, you can use an overlay; like Ontrack Disk Manager; with DOS or NT it would be fine up to 2gb @ the point of the install. With NT4, you could go even bigger but the install partition can't be any larger than 2gb. Once installed, you can partition the rest from within the OS. I've used this on stuff as far back as 386's that pretty much had zilch for HDD support.Leave a comment:
Windows? What's Windows?
The K6-233 is running Linux (and DOS...)
BTW seems a lot of older 486 boards have a coprocessor socket for 487's... which only makes sense if the main processor socket had a 486SX in it. Of course the 487 was an entire 486DX and simply disables the 486SX.
What would have been fun is that the board was SMP capable and ran two 486 integer cores and the FPU of the second CPU...alas, nope.
https://www.cpu-world.com/CPUs/4167/index.htmlLeave a comment:
Just photos with this post.
Starting off with a shot at the upper half of the case.
Temporary hard disk. Due to BIOS bugs, it doesn't work properly in this system. In fact, no hard disk above 528MB will work with this system.
Working I/O card pulled from the cheap-and-nasty 286 clone system.
A better view of the extent of the corrosion. Battery long gone by this point.
Damaged I/O card, not cleaned up.
Here's the cheap "NE2000-compatible" clone-of-a-clone network card that doesn't work with hardly anything I can throw at it.
Sound Blaster Vibra/16 card.
Lugged it home last weekend. Here's it all set up, running SpinRite 6.0 because I suspected hard disk problems.
As I said, this large of a drive just doesn't work on this system. This was the end result after trying to install MS-DOS 6.22.
And this is the end-result of trying to run Windows 98 setup because why not.
That's all I've got for now. More to come later.Leave a comment:
What would have been fun is that the board was SMP capable and ran two 486 integer cores and the FPU of the second CPU...alas, nope.Leave a comment:
I have an old gateway p5/90 case that looks very similar to this 486dx2-50...full size AT case, board is long gone. It has a K6-233 (with 256MB SDRAM on a 430TX...) board in it now.
Alas no nostalgic value to me, it's still a bit too fast to run my old EPROM burner software...
"Black to black, back to back" ... if they didn't cut out the right keys on the board and plugs.
I didn't even know that some boards had keying, not that I'd trust it anyways. Black to black and you'll be back! Red to red, motherboard dead!
I read your reply, but ATM, just have time for a quick reply...
re: power plugs. If the reds were together, +5 was grounded via the chassis, if metallic motherboard mounting was intact. Some of those old ones used nylon standoffs & fiber washers, so it wouldn't always trip the power supply- in which case "motherboard dead." And even if the short on +5 shunted that rail, the other voltages could still damage stuff during the brief period they "twitch."
re: HDDs- Maxtor 7xxxAT series were OK, and period correct.
My first real PC had a 7245AT- came to 230ish MB after formatting.
Great spinup sound, too!
The sound that meant "we're firing up the PC & doing serious work."
And they had "artwork" on the PCB; each capacity had its own "feature," IIRC.
ST3660A was OK too, had one of those alongside the Maxtor.
Was interesting setting the jumpers- these weren't simply "master-slave," etc.
You should be able to find charts to jumper them for operation on the same cable.
If you get around to cleaning the corrosion off that motherboard and removing the model rocket igniters, you can still buy new ISA slots. I don't think it will last too long with that kind of corrosion, but at least it works for now. That's an improvement over some of the leaking battery repairs I've seen.
https://www.digikey.com/en/products/...WN-S420/927281
P.S.: Eaten trace is what seems to have killed the I/O card. It and the ISA slot took the brunt of the damage, as the system was stored upright for all of its life. I don't think that I'm going to risk pulling the 8042 keyboard controller, unless it's an EPROM (the UV-windowed things). I've powered the external battery connector off of an external supply and it holds time and settings fine, which is a good sign. I'll lug the beast home this weekend and clean the motherboard up and put an end to the corrosion.Leave a comment:
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
Channel: Schematic Requests ONLY!
04-25-2025, 07:01 AM -
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Channel: BIOS Requests ONLY!
Gateway ID49C04u ID49C11u Laptop Schematic...
Channel: Schematics and Boardviews
11-01-2024, 06:46 AM -
Gateway NV53 Series Laptop Schematic
Wistron SJV50-TR 09228-1 48.4FM01.011 Rev 1M...-
11-01-2024, 02:54 AM -
- Loading...
