Gateway 80486-DX2/50 Revival
Permanently Retired Systems:
Kooky and Kool Systems
sigpic -
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Re: Gateway 80486-DX2/50 Revival
haha, i like your antique 486 system already, because it has two components made in singapore, the wd hard disk and the creative sound blaster sound card. seems singapore was quite the IT manufacturing factory back during the day, then it all went away to other countries. same boat as u guys in the US but since this is not the vip room, i wont comment further.Comment
I've also seen a lot of tech that era with 'made in usa' on it as well; quite common then....but not now....but I'll leave it at that.haha, i like your antique 486 system already, because it has two components made in singapore, the wd hard disk and the creative sound blaster sound card. seems singapore was quite the IT manufacturing factory back during the day, then it all went away to other countries. same boat as u guys in the US but since this is not the vip room, i wont comment further.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Nope, it's a pair of bugs in the system BIOS that interact in a bad way.
Bug #1- BIOS reverts hard disk configuration to auto-detection on boot, cold or warm.
Bug #2- BIOS tries to implement CHS translation for >528MB hard disks, but doesn't implement it fully and the end result is spectacular corruption of whatever you write to the disk, not to mention that whatever you read from the disk also ends up getting thoroughly trashed if you wrote it to the disk before transplanting it into the 486 system.
So either I'll need a sub-528MB hard disk (in the works) or an add-in BIOS that completely bypasses the (critically broken) INT13h routines when a >528MB hard disk is installed.
I do, but it's that ISA clone-of-a-clone card that causes DOS to hang up. I'll need an actually decent network card to make that happen.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
That's not making a whole lot of sense in relation to eachother. Did you replace the batt with something/anything that will make it retain memory (bug1)?Nope, it's a pair of bugs in the system BIOS that interact in a bad way.
Bug2 would be technically negated by bug1, and that sounds like more of an issue with the IO controller. Try a different one? If these are known bugs, probably a BIOS update out there somewhere for it....
I wouldn't waste any time trying to hunt down a sub-528mb HDD; especially one that's actually GOOD.... Just get a 512mb CF card with an IDE adapter....and done.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Tried with external battery power, no change. The BIOS sees it as an IDE drive and forcibly resets it to auto-detection. Unfortunately, the BIOS also has halfway-implemented CHS translation. Ontrack Disk Manager actually fails to install due to the bugged BIOS, either with "Failed to install because of a severe error condition!" or a warning message saying that "This System's BIOS Does Not Fully Support Translation!"That's not making a whole lot of sense in relation to eachother. Did you replace the batt with something/anything that will make it retain memory (bug1)?
There are newer BIOSes available, but I haven't found a flash utility that I feel comfortable running against it, and I don't have an (E)EPROM programmer.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
MS-DOS 7 (hangs when loading ASPI drivers with the card installed). Can't determine the chip installed on it. (It's got this label on it that I can't remove. I could try to find the mfg. by looking up the MAC address.)Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
Tried Uniflash or Flashrom? I have used those on quite a number of mainboards (granted, most were 430VX/TX, VIA 580VPX and newer) and they usually work. Flashrom has quite a higher rate of good flashes - I've had cases where Uniflash didn't want to play nice.Tried with external battery power, no change. The BIOS sees it as an IDE drive and forcibly resets it to auto-detection. Unfortunately, the BIOS also has halfway-implemented CHS translation. Ontrack Disk Manager actually fails to install due to the bugged BIOS, either with "Failed to install because of a severe error condition!" or a warning message saying that "This System's BIOS Does Not Fully Support Translation!"
There are newer BIOSes available, but I haven't found a flash utility that I feel comfortable running against it, and I don't have an (E)EPROM programmer.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Uniflash said that their software is intended only for PCI-era chipsets. I have not looked at Flashrom yet.
EDIT: Flashrom doesn't appear to have any mention of ISA chipsets, so I'm ruling on the safe side (not compatible).Last edited by TechGeek; 09-29-2022, 06:13 PM.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
That's why about 15yrs ago I copied all their data to the NAS..... Many CDR's written back in the 90's packed with blissful things don't read anymore... I can reproduce them if I have to. Yea, I know....too little too late in your case....but I saw that coming (bitrot)!!<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
This is true to some degree, I have plenty of old world scsi plextor's here....but even those wouldn't read some of my old dark blue 650mb Verbatim 90's era CD-R's....but some would, but struggled. Glad I made the archive!<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
I've got an early-'00s Plextor IDE CD burner that works like a champ. I reserve it for systems that I trust to not blow everything attached to their power supply to high heaven.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
by ViroslashHello everybody. I need EC/KBC firmware for Gateway gwnc31514. IT5570E-128 its shorted-ground.
Board N14TB REV 1.2
Intel i5-1035G1 (Ice Lake, 10th Gen).
Thank you!-
Channel: BIOS Requests ONLY!
I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
I attached a pic of motherboard info
04-25-2025, 07:01 AM -
by Dan JohnGreetings everyone,
I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
1) On pressing the power button, the (power button) light turns on and stays on.
2) There is no boot, or anything on the screen.
3) The fan starts and stops a few times, then it stops completely.
4) The light on the power button remains on.
5) Battery not charging (original issue).
The original problem was that the battery was not charging, but the laptop still worked. My belief...5 Photos -
by aes1111Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
S/N 2GWTN15612BL2J21J008090...-
Gateway ID49C04u ID49C11u Laptop Schematic...
Channel: Schematics and Boardviews
11-01-2024, 06:46 AM -
- Loading...
