Does anyone have datasheet on Panasonic MH caps?
Re: Does anyone have datasheet on Panasonic MH caps?
Datasheet for the MH series (discontinued): http://industrial.panasonic.com/www-...ABA0025+0+9+SA
Nearest equivalent is Nippon Chemi-Con KMG Series (except that 2200uF 63V is not available), which are somewhat better.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Paxman_SwedeHello!
I have studied the board and...-
Channel: General Capacitor Questions & Issues
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
- Loading...
