Notebook hard drives
  • Maxxarcade
    • Jul 2006
    • 973
    I'm thinking of upgrading the hard drive in my Netbook (Toshiba NB205), and I wanted to see if anyone here had any recommendations.
    Currently it has a 160GB 5400 RPM Hitachi drive. The new one I am considering is a 320GB, 7200RPM WD Scorpio Black. Is there anything better for less than $100 out there?
  • kikkoman
    • Jul 2007
    • 691
    Re: Notebook hard drives
    you should reconsider.
    7200rpm HDDs put out way more heat than 5400s.
    I don't know your netbook but I assume it's already pretty crammed in there.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Maxxarcade
      • Jul 2006
      • 973
      This netbook runs pretty cool already, because it's only an Intel Atom single core (N280). I'm not too worried about heat. Mainly trying to boost performance as much as I can.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        curious, what OS?
        sigpic
        (Insert witty quote here)
        • Maxxarcade
          • Jul 2006
          • 973
          curious, what OS?
          Windows 7 Pro, 2GB RAM.
          Runs pretty good once everything is loaded, but opening programs takes a bit longer than I would like.
          • washu
            • Jul 2009
            • 310
            Do you need lots of space? If not get an SSD. I have an X25-V in my netbook and it made it much faster. You'll see a much bigger increase in speed than going with a 7200 RPM drive. Also your heat and power usage will go down, not up.
            • Maxxarcade
              • Jul 2006
              • 973
              I really need at least 320GB, because I use it to store the 1080P videos from my camera when I am on vacation trips.
              • washu
                • Jul 2009
                • 310
                SSD + USB 2.5" HDD?
                If you care about space then just get the biggest 5400 RPM you can afford. A bigger drive will still be faster most of the time. A 7200 isn't going to make a huge difference in performance, but it will hurt your battery life and produce more noise and heat.
                It's not the most accurate benchmark, but the difference between my 5400 and 7200 Seagate Momentus drives in the Win7 index is 0.1.
                • bgavin
                  • Jan 2007
                  • 1355
                  Check your interface. If yours is the older 1.5 SATA, your machine may not accept the 3.0 gb SATA interface. As noted above, heat is a factor. IMO, the slight increase in net performance from 7200 rpm isn't worth the additional heat inside a jammed laptop.
                  Understand that SSD drives die a sudden (and early) death. They are built on NAND memory technology, which has a limited amount of writes. Do not defrag, etc if you own an SSD because this increases the write count significantly.
                  I have an SSD in my company provided laptop. I back up my entire projects and documents daily to our team server. I cannot tolerate the complete and unexpected loss of my project data.
                  Hitachi has the highest rate of failure for me. Next is Seagate Momentus followed by various WD. The stats at Newegg show all makes and models have a very similar failure rate. I run a complete Data Lifeguard pass on all my WD new drives. Any failures at all, and they go back for an exchange. If you RMA to WD, you get a used/recertified disk with a shorter warranty.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    I'm pretty sure it has SATA 3gb. I can double check that tomorrow.
                    If I do replace the drive, I'll probably stick with WD. I've had too many Seagates and Hitachis go bad on me with desktop drives.
                    And apparently there are two versions of the Scorpio Black. One has a free-fall sensor, the other does not. The plain version is about $20 cheaper.
                      • 31144
                      i think you can get 500gig for under 100$ (u.s. that is), i dont know how canadian compares these days.
                      probably stronger given that country's like russia are buying canadian $ now.
                      • bgavin
                        • Jan 2007
                        • 1355
                        I upgraded my Inspiron E1505 laptop, but stopped at the 160gb size. It was more important to have fewer platters, than having a lot of storage I won't use.
                        My machine came with the 1.5 SATA interface, so I replaced it with the same. Good news, Newegg had the 160 5400 on sale for super cheap.
                        Be sure to run a full pass of WDC data lifeguard tests on you new disk. I've had several arrive clicking, DOA, or otherwise busted.
                        • Maxxarcade
                          • Jul 2006
                          • 973
                          Odd, I've had pretty good luck with WD's desktop drives... Are their laptop drives crap?
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2642
                            usually not..
                            my experience with WD: either DOA (clicking/bad sectors/no spinup etc.) or working fine.
                            and if it's working out of the box, it usually keeps working.. ie no dying drives after a month or so..
                            doesn't matter if the drives are 3.5" desktop or 2.5" laptop ones.. always the same thing.. lol
                              • 31144
                              maybe the ones that fail got battered in transit!
                              • eccerr0r
                                failing hard drives after sitting for years...
                                by eccerr0r
                                With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                03-02-2023, 10:33 AM
                                HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-07-2024, 07:12 AM
                                09-07-2024, 06:40 AM
                                HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-07-2024, 05:50 AM
                                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
