Uni laptop
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Uni laptop
    Originally posted by mockingbird
    Working battery or dead battery, the "working" battery won't be working for long since LION batteries just die based on time no matter how many charge cycles they've been through, and don't expect a several year old battery to hold more than 15 minutes, even if that.
    $195 AUD is a terrible price for either of those.
    I paid $280 for a dual core laptop and this was almost a year ago.
    At these prices I would seriously consider investing in a new laptop.
    I bought a compaq armada 1750 that had a li-on that still worked for 30min (2 hr original)... 6 monthes ago, a power brick hit it and wiped out the screen.
    boy, it was old. pII dixon core. ran 2k like a dream though...
    sigpic
    (Insert witty quote here)
    • mockingbird
      • Dec 2008
      • 5488
      #42
      Re: Uni laptop
      Man that is the second screen you cracked in one month!!!
      I found a Compaq "Notebook 100" in the trash 1 year ago with an AMD K6-2. Thing is built like a tank.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Uni laptop
        Originally posted by kikkoman
        if it's just for programming µCs why don't you ask around if someone can lend you an old lappy?
        -or try to get a different programmer. what exactly is it you intend to program?
        I was going to try the *borrow a friends laptop* technique but my father said it wouldn't be a good idea if say I broke it by accident or something alike.
        As for the programmer... it's what uni gives us to use... I can't have an opinion into what I get unfortunately.
        Originally posted by dood
        How about a Dell Latitude d400?
        Um. the D400 doesn't have inbuilt optical drive or a parallel port unfortunately.
        Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
        • stevo1210
          • Oct 2006
          • 4156
          Re: Uni laptop
          Alright. I've bought the Toshiba Tecra M2 off eBay for $195 and I shall be picking it up tomorrow from the seller's store. I did however ring the seller and ask if everything was okay (e.g. RAM slots, hinges etc.) before I bought it and he said they're all fine and if they have any problems, I can return it within 28 days for a full refund.
          As for wireless, I will use c_hegge's advice and use a PCMCIA card... I'll pray that I won't get cancer from the RF signals or drop it onto the floor LOL.
          • stevo1210
            • Oct 2006
            • 4156
            Re: Uni laptop
            ...I found this Netgear PCMCIA card in my drawer... It'll do the Wi-Fi job perfectly right?
              • 31265
              Re: Uni laptop
              well being Netgear
              it may take a while to get the right drivers - they often change chipset and keep the same partnumber.
              but it will work.
              however, there is probably a mini-pci slot in the laptop for an internal modem/wifi
              i'd take a look and see if there is - and if the antenna cables are there.
              • mockingbird
                • Dec 2008
                • 5488
                #47
                Re: Uni laptop
                Did you see if you could get a Dell Inspiron 4150? It seems to fit the bill.
                As for the WG511t, it is Atheros based, thus very good.
                  • 31265
                  Re: Uni laptop
                  if it's atheros then install linux and load up Aircrack-ng
                  • mockingbird
                    • Dec 2008
                    • 5488
                    #49
                    Re: Uni laptop
                    You can run aircrack on pretty much any old chip out there today...
                      • 31265
                      Re: Uni laptop
                      no you cant, go look at the compatability on the site.
                      firstly forget windows.
                      second, a lot of chipsets wont do packet injection.
                      yes, you can sniff peoples data, but that's not much use unless you can inject stuff too.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Re: Uni laptop
                        Okays... I got the Tecra M2 today and currently typing this out on it LOL.
                        It works great! and the Netgear WG511T card is a great combination with it.
                        Exterior condition is okay I guess... with scratches and paint chips through wear and tear (after all it is about 5 years old lol). Screen has two teeny weeny blemishes but apart from that everything else is okay and works the part.
                        • mockingbird
                          • Dec 2008
                          • 5488
                          #52
                          Re: Uni laptop
                          You're behind the times. This used to be the case. Today, so many of the chips support packet injection and monitor mode. I've had success with pretty low-end parts.
                          Glad you are happy with your Tecra.
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: Uni laptop
                            Um... what key do I press to access the BIOS? because the start up splash screen doesn't tell me...
                            • stevo1210
                              • Oct 2006
                              • 4156
                              Re: Uni laptop
                              Got it at last... Esc + F1 to access the BIOS. I kept trying F2 only to find that it would freeze everytime LOL.
                              I had to adjust the boot sequence to 1st boot the HDD otherwise it would always seek the CD-ROM drive.
                                • 31265
                                Re: Uni laptop
                                open all the service covers you can see,
                                see if it has a mini-pci socket.
                                here's a hint - it looks a lot like the ram slots.
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  #56
                                  Re: Uni laptop
                                  It won't help him. If you put a wireless card into an empty mini pci slot but the screen assembly has no antennas built in, it won't work very well at all...
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Re: Uni laptop
                                    I think it should have an inbuilt antenna... but I seriously cannot be bothered opening it up and fiddling around with it because I'll probably break something LOL.
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: Uni laptop
                                      I'm missing this driver for my Tecra and I'm not sure what it is exactly. Even installing the Intel chipset drivers didn't solve it.
                                      So what could this driver be?
                                      • mockingbird
                                        • Dec 2008
                                        • 5488
                                        #59
                                        Re: Uni laptop
                                        Click on the details tab, I need to see the PCI_VEN.
                                        • stevo1210
                                          • Oct 2006
                                          • 4156
                                          Re: Uni laptop
                                          Is this the extra detail you needed?
                                          It says 'ACPI' so I'm thinking it might be a power related driver?
