"Netburst Mercedes" - a rather simple yet "exotic" build
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Figured I should make a own thread so as not to hijack Topcat's thread.
    Just as the title says, this machine is basically a "Netburst Mercedes". From the case, all the way to the innards, IMO.
    First, let's take a look at the specs:
    Mobo: Gigabyte GA-8IG1000 Pro w/ FGx BIOS (special BIOS revision made by AGFA for their dlab.1 MPU machine.)
    CPU: Pentium 4 HT 3.00GHz Prescott - will probably replace it with a Northwood HT as this Prescott is literally HELL incarnate. Wish I'd be joking, but it's absolutely true.
    PSU: revamped Deer/L&C LC-B400ATX (strong heatsinks, 35 size main trafo, complete main filtering, recapped with good caps, and sleeved wires out of a totally busted Thermaltake.)
    RAM: 4x512MB, nothing special
    ODD: some random Lite-On that is literally not even reading discs
    GPU: Sapphire Radeon X1650 Pro 512MB DDR2 AGP8x
    HDDs: 80GB Hitachi Deskstar as OS drive, 74GB WD Raptor as storage.
    Soundcard: Sound Blaster Audigy SE SB0570 PCI
    Other: Pinnacle PCI TV Tuner that I have no idea of its model number.
    To do:
    - replace the absolute Prescott furnace with a 2.8GHz Northwood HT. Cooler operation and doesn't murder the PSU as much as the Prescott currently does (not really, it's just running hot and loud - Deer's thermal controller works surprisingly well so no wonder the fan is loud.)
    - replace the ODD with either an LG or Samsung
    Finally, I'll leave some pics.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: "Netburst Mercedes" - a rather simple yet "exotic" build
    Should I be happy, I don't have any more (stable) P4's. I have one preshott 3.4GHz (775, i915; machine crashes randomly) and a HT 3.0GHz Northwood (478, i865; machine crashes under load reporting overheating)...
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I have a similar build going on now!! Welcome to the party!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        Looking back at the original post, I now realize I forgot mentioning the mysterious Mercedes styled case! It's a Linkworld 3210 (yes, Stinkworld) case I was given for free, that had been in rather rough shape.
        It's ever so slightly rusted, but in much better condition than when I got it nevertheless - I had matched it with parts from another Linkworld case of the same construction (a 313G I think) that was rather ugly but had same kind of chassis. Same goes for the drive covers - they came from that scrapped case, despite not being fully compatible.
        I also modified the front LEDs so that they match my main PC's configuration - thus, there are two green power LEDs put together, along with two amber (which will probably be replaced with red and white-based green LEDs) HDD leds.
        Left to do to the case is also glue some rubber standoffs - the case only has some slight pits that act as standoffs and you can imagine how bad the case would drift on wood. Surprisingly cheap yet good case, otherwise.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          Also sorry for double post. Replaced DVD drive with some older Liteon unit dated ~2003. It's white, but it seems to still read discs like new.
          Also replaced the SATA cable as I had issues with the old one.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Funny, I don't think I've ever seen a bad SATA cable!
            Team : 49813
            Join in!!
            Team Stats
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              I've had quite a few. Their ends are a bit longer than usual and they have horrible plastics. I had a spare cable left (dunno where it was from though) and installed it.
              Still dunno why XP would give me a "Error loading operating system" on restart when trying to install it on the Raptor. Installed fine on the Deskstar though, so didn't poke it too much.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                HA! You weren't kidding with that tittle.
                I figured when you said "Mercedes", you just meant a cool P4 build... but I see it now - the case IS actually very much like a Mercedes front.
                That's actually really cool.
                I've seen the same "BMW" cases with the carry handle on top and whatnot. Always thought they looked tacky and yet cool/unique for that era at the same time. In any case (pun intended here), I still find these a lot more interesting than the modern cases with RGB LED fans on the front and boring glass window on the side.
                Well, good sir, you are running a stock "low-TDP" Willamate/Northwood CPU cooler in that build... so no surprise your Prescott is running hot. Even the 2.8 Northy might run a bit hot with that. The proper heatsink for 2.6 GHz Northwoods and up has slightly more fins. And the Prescotts usually run all copper or Alu-heatsinks with copper inserts. I've seen only a handful of stock all-aluminum heatsinks for Prescott and they were... THIC.
                Do you have a stock s775 "full-height" cooler with copper insert? If yes, those will do for the Prescotts. AMD's 89W TDP heatsinks from the AM2/AM3 era would also be suitable. But of course, this would require ghetto-modding.
                As for it being worthwhile - maybe. Depends what you're going to use the system for. If just for retro games, the Northwood will probably do just fine. But if some browsing or video-related stuff will be done, the Prescott is actually considerably better due to extra cache and SSE3.
                https://www.badcaps.net/forum/attach...1&d=1646761495
                Nice!
                Did you add that heatsink on the bridge yourself or did the video card come with it?
                Either way, this is THE ONLY way those cards should be used. Otherwise, the bridge chip is a common failure for these cards, rendering many of them broken after some years of use.
                Really glad to see yours has it.
                Stinkworld PSUs were never that great... but their cases - not bad!
                Do you have the side for that case? If so, consider adding a rear exhaust fan. Pentium 4 systems do need them. PSU fan likely won't be enough.
                Maybe?
                I used to not care for P4 CPUs, but now do appreciate them - not just for "retro" PCs, but how much useful system life they can provide. FWIW, P4 CPUs are the only ones from that mid-2000's era (particularly the HT Prescotts and Northwoods) that can still be used on the web today. Yes, they are very very slow... but they'll get you from point A to B eventually. Athlon XP - nope, can't use any more due to lack of SSE2. Athlon 64 in socket 754 variant? - kinda weak for web use, and especially YT/video. Same goes for 939.
                I have the fastest single-core 939 CPU - the FX-57, running at a "blistering" 2.8 GHz. How does it compare to my 2.8 GHz P4 Prescott HT? - It's much faster in games and when processing website scripts online. But give it video encoding/decoding, and it chokes badly, especially on YT - can't even do 480p without dropping frames... which is funny, because it otherwise loads the YT page (and it's terrible scripts/comments) about 3-5 times faster than the 2.8 GHz Prescott HT. But once the video starts, it's a PowerPoint presentation. In contrast, the 2.8 GHz P4 Prescott HT takes much longer to process through the scripts on the page (tested with the same video, browser, and video acceleration settings - or lackthereof)... but once those load, I can even watch 720p if the bitrate is low enough. 480p is generally OK without dropping frames if I don't task the CPU with doing anything else in the background.
                So yeah... as bad as we think those P4's are, they are the only "old" CPUs from that era that can still be used online today.
                Same.
                ... except for a few user-damaged ones, where the top part above the contact pins was literally broken off from excessive force.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  • Romania
                  You mean the C91249-002 shown like in the photo? If so, I remember having tons of these, and they do have the copper base. I'll check to see how those fare against the stock Willy/early Northwood heatsink.
                  As for AM2 heatsinks, not really doable, unless I use ASRock's funny rentention bracket from the 754/939 era, which is basically a 2-in-1 contraption of the 478 and 754/939 retention systems. I think I have some of these too.
                  Guess the Prescott will stay then! I would want to have browsing capabilities and video related features so I guess the Prescott's SSE would come in helpful.
                  Nice!
                  Yes, it's superglued in there. I had artefacts before glue-ing it in there, along with a X1300 exhibiting the same symptoms. Speaking of which, I think I should bring that one up to snuff as well.
                  The side panel isn't really anyhting special, though I figure a 92mm (or at least that's what I think the case fan size is.) will probably help.
                  As for PSUs... I think I still have some "Stinkworld" PSUs I could patch up - these were actually among the few that you could fix and have a semi-decent 250W unit. If you don't count the absolutely dumpster-fire half-sized units, that is. Their standard full-sized units were okay-ish though (bar the abysmal cap choice, that is.) once recapped.
                  Main rig:
                  Gigabyte B75M-D3H
                  16GB DDR3-1600
                  Delux MG760 case
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Northwood P4's are all 32 bit right? BTW that heatsink/fan looks like the one I have on my Northwood...stock hs/f for S478.
                    At least Prehotts are all 64-bit capable and were able to boot my 64-bit Linux images. Except now I have a Celeron 430 to do that honor instead of the flaky Preshott motherboard...
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      • Romania
                      IIRC Socket 478 didn't have EM64T except one CPU, SL8JX. Mine is just a normal 3GHz HT, no EM64T.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        https://images.prom.ua/1465999940_w6...rotsessora.jpg
                        Heh, I've actually never seen those before... but they do look like they have more fins, so I think they should cool a little better. Give it a try and see.
                        I guess I'm more accustomed to Dell and HP/Compaq (OEM) builds - those always carried some type of copper or heatpipe stuff for the P4 CPUs. So if you do have a source of such old systems in your area, you should be able to find some suitable coolers then.
                        I think I know which ones you're talking about, as I have two from my 939dual-sata2 boards. Did they actually fit s478 mounting holes? Would be interesting if they did.
                        Well, the difference between the NW and Prescott might not be that great... but still, P4 is long architecture and often constricted by its "small" cache... which is where the extra 0.5 MB on the Prescott helps a little. Otherwise, IIRC, the NW had slightly better IPC than the Prescott - imagine that, lol.
                        Nice!
                        Whatever works.
                        But yeah, those bridge heatsinks were necessary. Too bad too many manufacturers cheaped out.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I was looking at some benchmarks between the 3.4GHz P4 (Preshott, 2M cache) and my Celeron 430 (Conroe? 1.8GHz). For integer operations, IPC wins and the Celeron at 1.8GHz is pretty darn close to a 3.4GHz P4.
                          However, pure floating point operations, ...
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            • Romania
                            Still a WiP at this point as some stuff needs attention or doesn't work. Not the most period correct either but I make do with whatever spares I have for it.
                            AMD K6-2 500 (non-plus)
                            Chaintech 5AGM2 mobo
                            ANS LC-B400ATX PSU (rebuilt)
                            20GB Maxtor 5T020H2 HDD
                            TRENDnet RTL8139D NIC
                            ASUS FX5200 128M GPU
                            Hitachi LG 4167B DVDRW
                            Currently having some issues as I originally wanted a 98SE/NT4 dualboot. Will probably end up with using a server version of 2000 in place of NT4 instead. What isn't working on it is the serial port bracket I'm using. Will have to source an even older one.
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              MSI Stealth 16 MERCEDES-AMG A13VG-0015F2-245 Notebook Specification for Upgrade or Repair
                              This specification for the MSI Stealth 16 MERCEDES-AMG A13VG-0015F2-245 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 MERCEDES-AMG A13VG-0015F2-245 boardview and 16 MERCEDES-AMG A13VG-0015F2-245 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-07-2024, 07:20 AM
                              by momaka
                              03-12-2025, 03:42 PM
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                            • FALKLAN
                              Mercedes-Benz W163 Bose Audio System
                              by FALKLAN
                              Howdy everyone!
                              I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                              On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                              12-07-2023, 11:22 PM
                            • Bugeur
                              Diagnosis Pad 2 / Mercedes Benz Winmate M133WK M133DA-100
                              by Bugeur
                              Hello everybody,
                              I have Bios with same chips. I would like to erase password. I could download two files from manufacturer. But it can't remove password after flashing chip.
                              I have a Xentry Diagnosis Pad 2 / Mercedes Benz under Winmate M133WK. It is a toughpad.
                              The motherboard name, if it can help is M133DA-100.
                              I already dumped U92 chip, U89 chip, U51 chip and U65 chip (needed to unsoldered it for read it).
                              On which bin files the password is located and how can I read it.
                              Thanking you in advance.
                              04-05-2023, 08:00 AM
