Dell XPS420 @4.32GHz
  • Retrorockit
    • Feb 2020
    • 105
    I finally quit screwing around with Optiplexes and lit the fuse on an XPS420. QX9650, 12GB DDR2 800, GTX1660TI, 2x 120GB SSD in RAID0.
    150x50mm Delta 2cpu workstation fan, and XPS720 BTX heatpipe cooler.
    13x333 1.425V. and holding about 70*c. Dell wait too long to speed up the fan. and I'm just using a theram; pad so far. Lapping, TIM, and tuned fan profile are coming next.
    CPUZ base score 270/1049
    OC score 390/1495
    I haven't connected it to the internet yet so no benchmarks.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
  • lalle-
    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
    by lalle-
    Hello!
    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
    08-11-2024, 02:01 PM
