Does After Dark 3.3 copy files or take images?
  • ZuluLima
    • 35
    • U.S.A.
    I have After Dark v.3.3 installed on a virtual 95 plus machine. This question is pondering me. Does the dos command screensaver copy files or does it take images? You do see the files of your virtual drive on this screensaver. I really don't care since it's a virtual machine. Anyone know about this? Also, where can I find the Simpsons After Dark Screensavers?
  • AudioCraZ
    • Sep 2009
    • 147
    Re: Does After Dark 3.3 copy files or take images?
    Wow, been years since I seen After Dark.... FLASHBACK!
    From what I remember, it just loads its own stuff from its install directory. As for adding images, I don't remember. Been so long. From what I remember, it is all pre-installed screensavers. The best place to look is readme files that come with the software, or google/bing searches.
    • Rozp
      70LE660U dark cloud or black screen with sound.
      by Rozp
      Hello Everyone,
      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
      08-29-2023, 05:25 PM
      Copy DMI info easily with Hex editing software and Macro script
      by SMDFlea
      Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
      Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
      02-28-2023, 02:14 PM
    • Caimano
      Need to copy DMI info for HP ProBook 650 G2 Bios
      by Caimano
      UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
      Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
      01-03-2024, 05:19 AM
    • Danstona
      LG 65UK6090PUA - picture dark
      by Danstona
      Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
      bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
      I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
      03-10-2024, 12:41 PM
    • bohaboha
      Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
      by bohaboha
      Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
      anyhow i couldn't t read anything else
      the backlight is on strong and the screen does not get dark or very dark but no pictures
      the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
      01-02-2025, 08:04 PM
