msoffice / samba problem
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i was finally getting my shit together to launch the new linux server at work. it is months delayed, i have so much shit to do. i thought the config was finally ready but testing today revealed a weird problem.
    the last issue was that the documents on the server were read/write only by the creator of the file. the rest got it read only. i changed the samba conf to make the owner of the file the creator and the users group get read/write. so this solved the problem and all users get read write.
    so i was doing some testing and had a word document open. word is set to save autorecovery every 10 mins. but when it saves an autorecovery i periodically get "autorecovery is postponed". it is msoffice 97 (yeh i am trying to get 2003 passed through the budget)
    since the creating, saving, opening of word files is no prob i assume that there is a permissions prob for the autorecovery files also. the users are logging on fine though.
    i will post my samba conf tomorrow and other log files if someone can assist, pls tell me what i need to post. i found few info on the net also the great wisdom of turning off autorecovery which is not an option.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: msoffice / samba problem
    ok i solved this one. the solution was to make a public samba share to use as a scratch disk for the word autorecovery files.
    [scratch]
    comment = Users Temp Files
    path = /home/scratch
    browseable = yes
    read only = no
    public = yes
    writeable = yes
    force create mode = 0777
    force directory mode = 0777
    you can set word 97 to use a specific location for the autorecovery files in Options/File Locations
    basically what happens is there is some problem with permissions of the autorecovery files when they are stored by default in the samba share from where the file was opened or created. basically word wants to make these files, delete them, rename them etc.
    another way to do it was to set the autorecovery files to be located on the users hard disk. this was not possible since we are using win2k ntfs so there are permission problems there also. i think it would be possible on fat32.
    another problem i solved today which i was worried about was the slow upload to the server from my computer. download was fine. i thought i was going to have to config the switch better and start reading up on cisco ios or get into nic driver configs etc, samba tweaks....... no the lan card i had used was hardware set to 100mb half-duplex. i picked that up on the show interfaces on the cisco.
    setting it to auto, auto made the upload fine (whew)
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
