Wireless Lappy
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Wireless Lappy
    I took the back cover off my Dell C640 Lappy and I found what I think is a wireless adapter in it. Its a daughter card with what looks like two antenna on it. Got to poke around the Dell site and try and find some drivers for it. There is still one "unknown device" listed under system and it has to be this wireless looking thing! This is going to be fun. I've never set up a wireless network on a PC. The first thing I will have to do is go to the Westel page and turn the wireless side of my DSL modem back on, and do the WEP and all that good stuff.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
    • 31033
    Re: Wireless Lappy
    i use a Linux livedisk to id the chipset, then get the latest driver from the mfr homepage.
    the same with audio etc.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Wireless Lappy
      not wep
      use wpa
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Re: Wireless Lappy
        Ok thanks! WPA it is then. I don't have time to mess with it today. Will Ubuntu or Mint Linux work in a live disk mode to ID the chip set?
        Mark Twain
        John Paul Jones
        Rod Serling
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Re: Wireless Lappy
          http://support.dell.com/support/down...&catid=&impid=
          All the drivers you need.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Re: Wireless Lappy
            Well it wouldn't run Mint Gloria in live disk mode. I then tried Ubuntu and it did run somewhat. Next I did and install of Ubuntu and it took hours. Ubuntu wouldn't boot after the install but I could boot to Xp. Its now slow as hell too. The hard drive light is almost aways blinking. Its time. I'm just going to reprogram it on the next rainy day. Now I have to remember how to recover the space used in the old Mint install as well as the new Ubuntu install. That Lappy has been a pain in my ass since the day I got it. She works great when she works. When its sick its a total POS! It must have been built by Ford or Chrysler.
            Mark Twain
            John Paul Jones
            Rod Serling
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: Wireless Lappy
              how much ram does it have?
              or maybe the hdd is screwed
                • 31033
                Re: Wireless Lappy
                probably a bogus acpi table in the bios to sabotage Linux - it's common.
                when you boot the livedisk, set the boot options to not use acpi, dmi or any other lookup tables in the bios.
                • seanc
                  • Nov 2008
                  • 1319
                  Re: Wireless Lappy
                  I second the bad disk comment, it's an old laptop, probably seen better days by now.
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Re: Wireless Lappy
                    It has 512 megs of ram. The Hard drive has never given any problems.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • seanc
                      • Nov 2008
                      • 1319
                      Re: Wireless Lappy
                      As good a time as any for it to start. Download speedfan and post the results of the online analysis here.
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        Re: Wireless Lappy
                        The Lappy is all reprogramed now. It works fine. I still have not figured out who made the internal wireless adapter. Someday I will.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                          • 31033
                          Re: Wireless Lappy
                          99% chance it's a shity Intel Centrino card.
                          • digge
                            • Apr 2006
                            • 296
                            Re: Wireless Lappy
                            If you have windows up and running try siw found at http://www.gtopala.com/siw-download.html to try to find out what kind of device you have. Doesn't work 100% to identify any hardware but works for most common hardware to identify vendor at least. And if you can just get the vendor id and all that you can start googling and find more details.
                            • seanc
                              • Nov 2008
                              • 1319
                              Re: Wireless Lappy
                              You could also get the identifiers from Device Manager:
                              You see VEN_8086&DEV_1075 IN in my screenshot, if you Google 8086:1075 you'll get some hints as to what the device is.
