Non-standard names and symbols for Wi-Fi Protected Setup
  • japlytic
    • Oct 2005
    • 2086
    There are wireless access points and clients which support Wi-Fi Protected Setup, but some manufacturers use another name for this feature and/or a symbol other than the official “cycle” logo on the pushbutton for this feature .
    Under Windows 7, if the client supports Wi-Fi Protected Setup (PBC method) and the access point has the PBC method enabled, the official “cycle” logo is used when a prompt appears to press the button on the access point.
    It is strongly recommended that all manufacturers that produce wireless access points and clients that comply with the Wi-Fi Protected Setup specification to only use this name for this feature, along with the Wi-Fi Protected Setup button only having the official “cycle” logo.
    To date, Linksys/Cisco and D-Link use the official "cycle" logo on the Wi-Fi Protected Setup button on wireless access points and clients, and I commend them .
    Do you know of any others which do that too?
    Others often label the Wi-Fi Protected Setup button "WPS".
    Some use a symbol other than the official "cycle" logo on this button. These include: 2Wire (radiating spot), Alcatel/Thomson (radiating antenna), Belkin (padlock for some models), Draytek (unofficial "cycle" logo), Netgear (radiating padlock), and TP-Link (QSS).
    Have you seen any other symbols for this function?
    The most notable names other than Wi-Fi Protected Setup (which comply with this specification) are Pusn N' Connect (Netgear) and Quick Secure Setup (TP-Link).
    Do you know of any other names?
    Note that Buffalo AirStation One-touch Secure System (AOSS - also supported by some gaming platforms) and SecureEasySetup are different from Wi-Fi Protected Setup.
  • NxB
    • Feb 2009
    • 1595
    Re: Non-standard names and symbols for Wi-Fi Protected Setup
    Or you just set up your encryption manually. I don't see the point of this button; other than fucking up what I set up if I happen to press it on accident.
    What does it set anyway, wep?
      • 31151
      agree - people shouldnt be given an "idiot-button", they should be encouraged to RTFM and set the thing up properly.
        • 31151
        • japlytic
          • Oct 2005
          • 2086
          A campaign to standardize Wi-Fi Protected Setup names and logos:
          http://www.youtube.com/watch?v=eefemNmEQP0
          • japlytic
            • Oct 2005
            • 2086
            ASUS should be commended as well, because I saw they had an RT-N13U which uses the official "cycle" logo (and WPS) on the button for this function
            • japlytic
              • Oct 2005
              • 2086
              I asked Draytek, EnGenius, Netgear and TP-Link to seriously consider using the official name for this function, along with the button for this function to have the official cycle logo.
              So far, no response, even from the Wi-Fi Alliance when I asked them to seriously consider requiring manufacturers with equipment which complies with the Wi-Fi Protected Setup specificiation to only use the official name for this function, and again, the official cycle logo on the button for this function.
              Attached is the use of the official cycle logo in Windows 7.
              • japlytic
                • Oct 2005
                • 2086
                Update: Technicolor now uses the offical cycle logo with "WPS" text for this function on their latest wireless equipment.
                A step in the right direction - they should be commended .
                • Modify_inc
                  Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                  by Modify_inc
                  I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                  11-02-2021, 11:14 AM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • notallbad
                  Samsung UE55JU6000K stuck at 'Setup Conplete'
                  by notallbad
                  Reset the tv as internet connection not working, connected to router but no internet.
                  Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
                  Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
                  Its already on T-HKM6DEUC1570.0 fw.
                  Are the SVC reset options likely to help here?
                  options are
                  apps reset
                  svc reset
                  spi flash reset
                  data sync reset
                  Any help appreciated.
                  08-26-2023, 10:44 AM
                • remizbushka
                  Dell inspirion 5775 bios "Unlock Setup fail"
                  by remizbushka
                  Hi sirs. please help
                  Dell Inspiron 5775 bios locked "Unlock Setup fail"
                  After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                  What I did:
                  I read the bios dump.
                  Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                  03-24-2025, 09:07 AM
                • B83C
                  HP elitebook x360 1040 G5 Stuck at 'Entering setup menu...'
                  by B83C
                  Received a faulty HP elitebook from my friend that does not boot up properly. The internal display is broken, so the only way to view the display output is via hdmi. However, when booted up the screen get stuck with 'Entering setup menu...' when esc is pressed upon booting. HP logo isn't displayed on bootup, only black screen, but an underscore cursor appear on top left corner of the screen. Has anyone any idea what could be the culprit here? I have flashed both the EC and BIOS flash but to no avail. The serial number is 5CG9377GCT, and below is the original flash content:
                  Also the...
                  02-03-2025, 08:28 PM
