Wi-Fi Protected Setup pushbutton disabled by telco-provided modem?
  • japlytic
    • Oct 2005
    • 2086
    Yesterday, I was setting up a Telstra-provided Thomson TG782T broadband modem/wireless access point for a customer. It supported Wi-Fi Protected Setup (it had a pushbutton for this function).
    When I tried to connect with my laptop with the Wi-Fi Protected Setup method, the Telstra access point would only allow connection with the PIN method, even though I successfully connected at home (with a non-telco supplied access point) with the PBC method.
    Apparently, the Telstra access point has the PBC method disabled.
    Do you know of other telco-supplied access points with the Wi-Fi Protected Setup with the PBC method disabled (only allows the PIN method)?
  • kikkoman
    • Jul 2007
    • 691
    Re: Wi-Fi Protected Setup pushbutton disabled by telco-provided modem?
    i have a Thomson TG585 v7 that does have a pushbutton but it doesn't work at all (it's not mentioned in the config either). it's not lit up (i think it usually should).
    i got it from my provider, so it had custom firmware (that used up 2 out of 4 LAN ports for IP-TV which i don't use anyway) but most importantly it frequently locked up and rebooted, especially when i used bittorrent.
    i flashed it to a known stable official FW and voilĂ , all problems gone.
    can't really say if the pushbutton setup worked before the flash.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Player2
      • Aug 2009
      • 98
      Ditto on reflashing with a non-customized OEM firmware. I had to do this on a D-Link (blech) WiFi router that was provided by Verizon with FiOS service. The router would drop connections constantly and the signal quality was abysmal. Of course D-Link had several newer firmwares that improved these issues, but Verizon never updated theirs. I had to force the router into a recovery mode to flash the OEM firmware, as the Verizon firmware rejected the OEM update through the normal admin console.
      • japlytic
        • Oct 2005
        • 2086
        I forgot to say, you need to press the Wi-Fi Protected setup button for at least 5 seconds to activate this function.
        • stevo1210
          • Oct 2006
          • 4156
          Why does Telstra have to do this to their routers? it drives me nuts too.... so much so that I left Telstra a year ago for good.
          • hotgly
            Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
            by hotgly
            After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
            The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
            I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
            Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
            Serial number: 0F00S2Y22353BF
            Intel(R) ME Code Versions:
            BIOS Version 12.200.143
            MEI Driver...
            05-15-2024, 02:20 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • spawnx212484
            Lenovo V15 G2 ITL ME DISABLED
            by spawnx212484
            I have a Lenovo V15 G2 ITL with the memory onboard defective... I disabled the memory in the bios via a utility on the forum and since impossible to detect the SSD NVME in the Bios...
            I've updated the Bios and EC but nothing changes... I thought of updating the ME frimware via Windows and I have a Log with the message ME Disabled...
            I don't know what to do, should I do a ME clean?
            Thanks​
            04-01-2024, 11:21 AM
          • Blackwolf76
            Dell 7420 wwan port disabled
            by Blackwolf76
            I have two Dell 7420s with the WWAN port disabled, probably due to a BIOS lock.
            I tried installing two different cards in both PCs, but neither of them detects it in the peripherals. I've reset the BIOS and tried everything possible, but the problem persists.
            The same cards on other PCs I've tested work perfectly. Do you know if there's a way to enable it, perhaps directly from the BIOS chip I read about?
            Thanks in advance for help....
            07-27-2025, 02:26 AM
            ASUS 3F-AP201C-A, Specification for Upgrade or Repair
            This specification for the ASUS 3F-AP201C-A, can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3F-AP201C-A, boardview and 3F-AP201C-A, schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS 3F-AP201C-A,...
            09-06-2024, 05:27 AM
