Conexant CX20833 full Datasheet
  • badboydas
    Noob
    • Jun 2010
    • 25
    Hi
    Searching for a full datasheet on the Conexant CX20833.
    I do have the details datasheet but not the full.
    anyone help please
    If it ain't broke I don't want it.
  • @udiophile99
    • Mar 2021
    • 14
    Re: Conexant CX20833 full Datasheet
    Originally posted by badboydas
    Hi
    anyone help please
    Believe it or not, there plenty of sites where you can find this. Here's one: Craiglist.
    • badboydas
      Noob
      • Jun 2010
      • 25
      Not after the component, I'm after the datasheet.
      • R_J
        • Jun 2012
        • 9624
        I think that was just a bot attack response. Is this the same as you have now?
        • badboydas
          Noob
          • Jun 2010
          • 25
          Sorry for the late reply.
          R_J your a star cheers.
          • Rainbow_Chameleon
            Searching Datasheet for AM113 IC by O2MICRO
            by Rainbow_Chameleon
            I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
            Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
            If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
            On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
            So if anyone has a datasheet or at least...
            01-23-2025, 12:03 PM
          • electomech-fixer
            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
            by electomech-fixer
            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
            09-15-2025, 01:42 AM
          • SoulFreeze
            Help finding datasheet for component marked G34662
            by SoulFreeze
            Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
            Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
            Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
            05-01-2025, 03:56 AM
          • cannifixit
            HP Elitebook 6050A3299901-MB-AX1 mystery model, need help identifying it
            by cannifixit
            I recently bought a faulty Elitebook from ebay, and that was exactly how it was listed just "HP Elitebook", no details.
            It has two issues, the first being in manufacturing mode for the bios, which from my understanding essentially means a bios has been flashed that does not have any of the laptops details, model, serial number etc.
            The second issue is it does not charge which I'm sure I'll be ok with once i get into it.
            The bios issue is a problem though as the laptop is missing all of the details on the bottom case, it's completely blank, it's not like they...
            06-24-2025, 03:50 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
