.dlna domain names
  • japlytic
    • Oct 2005
    • 2086
    .dlna domain names
    I did a search for the .dlna domain and discovered that it is not in current use, but I think such a domain should be able to be used on local DLNA servers with an easy to use name you enter into your web browser e.g. emby.dlna
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: .dlna domain names
    DLNA is pretty much designed to be local. Clients are designed that way. There is some software like plex that you can stream over the internet but you have to use their app. The concept of DLNA is only over your local network. As there is no authentication. The protocol is not designed this way.
    Although you can use a local VPN to join remote devices to your lan. that might work?
    • brethin
      • Dec 2008
      • 1907
      Sony offers a server clint for this for local machines.
      • brethin
        • Dec 2008
        • 1907
        You can also use Nas devices that do this, many buffalo nas servers do this. And provide web access.
        • Sushi1808
          Onkyo TX-NR609 Sound only on USB/Internet Radio/DLNA Input
          by Sushi1808
          Hi everyone!
          I turn to you in hope someone could point me in the right direction since I lack knowledge and experience in diagnosis of audio equipment. (My experience is in computer chip level repairs.)
          I bought an Onkyo TX-NR609 receiver which initially produced no sound on speakers/headphones, there was no delayed relay click, speaker matrix icon didn't show up, USB/NET stuck in "Now initializing", instead of DSP/1st NET firmware version there were ?????????...
          There was flux residue around the D830K013BZKB4 DSP chip (Q3001) on the HDMI...
          07-01-2023, 07:53 AM
        • ClockChip
          How long were the displays on consumer-grade 1980s-era LED clocks designed to last?
          by ClockChip
          Does anyone know? A recent thread has got me wondering if the folks who designed and built consumer-grade LED clocks in the 1980s ever envisioned them still being used in the 2020s or if they were designed to give out (i.e. planned obsolescence) long before then?
          Perhaps a better way to phrase this would be: does anyone here still use a 1980s-era clock as a daily timepiece? If so, do you expect to get many more years out of it?
          (Along those same lines, if it does eventually develop a fault, are you likely to try to fix it?)
          07-25-2023, 07:50 PM
        • iam5
          Intermittent USB-C / USB-A issues + Trackpad Freezes — T14s Gen2 (11th-gen Intel) — Seeking Board-Level Advice
          by iam5
          I’m looking for advice on board-level troubleshooting and potential component-level repairs for a Lenovo ThinkPad T14s Gen2 Intel (i7-1185G7) showing multi-domain instability. Hoping someone familiar with this platform (or the related X1 Carbon Gen9/Gen10, X13 Gen2, X1 Nano Gen1/2) can point me toward the right section of the board to inspect, and whether any of the known fixes apply. Symptoms:
          1. Trackpad (CS21 module) intermittently freezes during active use
          • Not tied to lid open/close
          • External USB mouse continues working
          • Sometimes recovers with sleep/wake
          • Looks like
          11-25-2025, 09:29 AM
        • Sileeth
          Remanufactured GTX 650Ti Resets and Driver problems.
          by Sileeth
          Hi!!! Nice Day/Night
          I bought a GTX 650Ti on Aliexpress, that could be the first problem... I think the card was built in a custom build version because it has 4 GB DDR5 of 2700 MHz memory (According to all programs except GPU-Z).
          With GPU-Z everything is fine except the value of the memory frequency, the software says that the memory frequency is 1350 MHz with reference to the original models of this graphic card.
          After opening the package, I disassembled the cooler and checked all the parts and the most important one, the GPU processor. Everything...
          05-26-2022, 07:12 AM
        • t4796
          Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
          by t4796
          I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
          Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
          From the FAQ I learnt that for 110v the power...
          10-25-2024, 06:59 PM
